Brake Pads
Old May 20, 2015 | 09:08 AM
ctuinstra's Avatar
ctuinstra
Default Brake Pads
I'm rebuilding the brakes all the way around and I'm looking for good brake pads. I don't need or want pads for racing, I don't plan to do any autocross, besides they are easy enough to change, I could drop another set in if needed.
I'm looking for pads that:
1) DON'T SQUEAK!
2) Grip like hell - I don't care if they wear out on 5K miles, that will take me over 10 years anyways.
3) I don't care about brake dust
I just want something that works well with manual brakes. Anymore all they make is long-life pads for our DD and they tend to squeak and wear the rotors, but they don't wear out.
I was looking at the Hawk Ferro Carbon.
Thoughts?
Old May 20, 2015 | 10:53 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Take a look at the Carbotech 1521 pad. If interested I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old May 20, 2015 | 12:30 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If it makes any difference, mine come over the counter at NAPA when I need them.
To Brake Pads
