Tires
Old May 21, 2015 | 02:10 PM
skip99202's Avatar
skip99202
Default Tires
Ive read hundreds of posts about tires but still undecided.
Id loke to use a wider tire than the 225 70 15 on the car now, assuming i can get the rear spring issue corrected, (in another post) the 225/70 just looks like you had to pull it apart to meet the wheel lip.
So, no problem there going to 245 /60 lets say...or whichever is same height slightly wider.
However. The 225/70 on the front right now is tight, like 1/4 in. From front fender lip and about the same to frame at full turn.
Any opinions on this? Would a slight rear stagger look ok?
I think id like about 1/2 wider tire just so the sidewalls look straight on the 8" rim
Old May 21, 2015 | 02:38 PM
MelWff's Avatar
MelWff
assuming you have no sagging springs or other issues the 245/60x15 will fit some people can even put 255/60x15.
Old May 21, 2015 | 02:43 PM
skip99202's Avatar
skip99202
You mean 245/60 front and rear?
Old May 21, 2015 | 02:51 PM
MelWff's Avatar
MelWff
yes front and rear
Old May 21, 2015 | 03:02 PM
bashcraft's Avatar
bashcraft
The 245/60 is 3/4" shorter than the 225/70's you have now. Even the 255/60 is 1/4" shorter, though that may not be noticeable.
The 235/70 may be what you're looking for.
Old May 21, 2015 | 03:15 PM
73Reprise's Avatar
73Reprise
Run 255/60 rear & 235/60 front on stock alum. wheels and suspension. No clearance or rubbing problems.
Old May 21, 2015 | 04:15 PM
skip99202's Avatar
skip99202
Same for stock steel ralley's ?
Old May 21, 2015 | 04:25 PM
skip99202's Avatar
skip99202
I just looked, there is anout 1/2 to 5/8 clearance to the ebrake bracket.
How close can i get?
If i hold a level against the tire 225/70, it is 1/2" away fromthe rim, meaning the tire is actually 10" wide. Because its stretched onto an 8" rim.
The charts say. A 225/70 is 9" wide.
So how wide is anyones actual 245 or 255/60 on a stock steel wheel?
Old May 21, 2015 | 10:41 PM
73Reprise's Avatar
73Reprise
To the best of my knowledge, specs are same on talley and aluminum wheels.
Old May 21, 2015 | 11:11 PM
Zero1Niner's Avatar
Zero1Niner
I have 255 60 15's on all 4. No problems. Well none related to that tire size that is. Car has plenty of problems.
Old May 22, 2015 | 01:44 PM
keithl1967's Avatar
keithl1967
I put 255/60's on the rear--no problem, and 245/60's on the front--looks great, fills the wheel wells, and no issues
Old May 23, 2015 | 11:26 AM
SLOW84VETTE's Avatar
SLOW84VETTE
After looking at a lot of threads and seeing a few cars in the flesh. I am leaning toward this combination for my 70
To Tires
