Hello, it's been a while since I've been on he site. I was wondering if anyone has encountered this before.
Just installed the 290 350 crate motor. Just got it started and timed. Timing mark looked steady @ 10 BTD running smooth. After the engine ran for a few more minutes the timing mark begins to jump. Let it sit overnight and started it again. The timing mark was steady. After it warms up the timing mark begins to jump and seems to miss a little. I'm running my original distributor with the petronixs ignition module. Could the petronixs module be going bad when it heats up or maybe my dist. is bad?
Any feedback is appreciated.
My guess is your vacuum is changing and you have a vacuum advance distributor? Are you using a standard or advance timing light? You need to disconnect the vacuum line and plug it to set base timing. I suggest using an advance timing light to make sure everything is working correctly but for base timing either type works.
Thanks Techman for the quick response. I timed it with the vac advanced unplugged and plugged the other end with a golf tee. I have a vacuum advance with a new can and Im using an advance timing light with the degree dial on it. Im running vac advance at the carb.
Maybe check the centrifugal advance springs and make sure it is working correctly. At idle it should not be moving but seems like there was a note I discovered when I installed mine about disabling it while setting timing. I can't find the note but if that moves at all the timing will move. Seems like I put tape around mine to make sure it didn't move, but it has been a few years.
I put on an Edelbrock ProFlow EFI and matching Mallory SSI distributor last year so everything has changed now :-)
Maybe contact Pertronix and see if they have some tips also.
Thanks for the input, I going to start checking my grounds to the dist housing also I am going to contact petronix.
A quick way to determine if an electrical component problem is heat related is to use a can of dust off or compressed air directly on the part you think may be bad. The air will cool down the part quickly. I would also check if your dist. hold down bolt is tight. Good luck. Jerry
Thanks for the input guys. Cleaned up and tightened down the hold down clamp. Also ran an addition ground wire from the petronix base plate to on of the starter bolts, let it warm up and the timing mark seemed to stabilize, vacuum seems good the lights pop up quick and when I hook up the vacuum advance can it makes a difference. Put it in drive RPM drops it bogs down and stalls. I have to advance the timing a hole lot to get it to idle in drive without stalling and when I advance the timing the idle starts to get rough. Im wondering if I need a new distributor. Running out of ideas.
You seem to be focused on the distributor but have you checked carburetor function, choke pull-off and idle mixture?
Hello Dochorsepower, The carb was rebuilt not to long ago. Carter Qjet. I do know the float sticks sometimes and makes it hard to start. If I tap on the inlet of the carb the engine will fire right up. Once its running its seems to get plenty of gas and the engine runs good at higher RPMs. I have adjusted the fuel air mixture set screws a little. They are about 2 and 3/4 of the way open. Doesn't seem to effect anything. Is there any kind of carb test I can do, like wiring open the butterfly valves a bit to give it more air?
[QUOTE=Captainkvan;1589683724]Hello Dochorsepower, The carb was rebuilt not to long ago. Carter Qjet. I do know the float sticks sometimes and makes it hard to start. If I tap on the inlet of the carb the engine will fire right up. Once its running its seems to get plenty of gas and the engine runs good at higher RPMs. I have adjusted the fuel air mixture set screws a little. They are about 2 and 3/4 of the way open. Doesn't seem to effect anything. Is there any kind of carb test I can do, like wiring open the butterfly valves a bit to give it more air?
Choke is wide open.
Choke is wide open.
Sounds like you have a vacuum leak and the idle is lean.
Make sure the accelerator pumps are squirting into the carb when you hit the throttle.
I also had a similar problem in my 71 with petronix and distributor. P/O had pryed the module up to get the recommended gap in order to get the correct timing at idle, but when going to a higher RPM it started to jump x dergee to x degree. what he failed to do was check the distributor. the distributor shaft gear was traveling up and down depending on the engine RPM, I order a shim kit, flatten the petronix module. Problem gone. My 2cents.
Mike
I don't believe you mentioned checking or re-lubing the mechanical advance system in the dizzy. If that gets dry/sticky, it will give you exactly the same symptoms as you described.
If it does not "jump" with the vacuum advance can vacuum line removed and plugged off, but you get "jumping" when it is connected to vacuum..the vacuum can could be defective.
Hey, I'm pretty interested in this thread, as I am encountering the same issue...
75 L48 68,000 mi stock
Stock dist recurved, all in around 3k.
Shimmed to ~0.015" end play.
New vacuum advance can @ manifold (vacuum plugged off to check tho).
at idle, get about a 4 degree sporadic jump (ahead) in timing... my portable tach picks it up too. tried both ends of the NR 1 wire, different springs, same thing...?
Just rebuilt the Q-jet, but based on the timing jumping and tach being funny, REALLY looks like an ignition problem.
Thanks, any ideas would be great.
Mike
Reason: Added year/model
Check end play in dizzy first. .020" for ALUM, .010" FOR IRON
Check cent. weights for slop on pivots.
Check for weak advance springs.
Disconnect the vacuum advance while checking timing.
Check for slack in timing chain.
If you have 20* mechanical advance, try 16* advance at idle.
If using points, check for slop in the base plate.
If using points, check dwell and spring tension.
Thanks, I'll check the timing chain for slop. Just funny, sporadic until revved - could very well be the timing chain
R
Mike
HEI?
Use stock weights and two gold springs from a Mr Gasket curve kit. Re-curve kits can be real crap.
Sporadic at idle? How is the gear? Cam end play?
All in by 3000 rpm is good.
What is the total mech advance at 3000RPM?
