crossfire cam question
Old May 28, 2015 | 09:16 PM
bensons82's Avatar
bensons82
Default crossfire cam question
So ive been thinking about putting a cam in my car. Im really not sure what to look for I dont want to go crazy I just wont good sound and mild hp its not gonna be a race car. Im not going to go it till this winter but im trying to preplan it. Im also going to port the intake this winter. Not sure what else I should do yet I just want to do a mild build on it. So if anyones got some idea id be happy to hear thank you
Old May 28, 2015 | 09:44 PM
toobroketoretire's Avatar
toobroketoretire
If its still subject to smog testing you'll have to go with less than 220 degrees duration and keep the stock PROM in it.
Old May 28, 2015 | 09:49 PM
Drawmain's Avatar
Drawmain
I put a Voodoo cam in mine, but I also did heads and a renegade and a full rebuild at the same time. I ran the stock computer with the rebuilt engine with no issues for a few months. I ended up swapping out to an aftermarket ECM when my ECM tanked (unrelated to the rebuild) and my "new" injectors crapped out. The part number on the Voodoo I used was
10120701. 256/262 advertised, 213/219 @ .050. Others in the past have used the Crane 2030 and Crane 2040 cams without swapping out the ECM. Porting the intake is a good idea. While you are at it remove the EGR chamber as well, it is a huge restriction inside the plenum.
Old May 29, 2015 | 01:18 PM
hugie82's Avatar
hugie82
Idle vacuum going to the MAP sensor is where our cars run into problems. The two numbers you need to watch is duration. Needs to be under .220 @0.50 and lobe separation. Should be above 112
You can cheat a little with Rhodes lifters or go with a roller cam but for a good all around cam. Go with the recommended cam choices. From here, edelbrock or comp cams has a listing for our cars that are bolt ins.
Old May 29, 2015 | 02:03 PM
bensons82's Avatar
bensons82
i checked out the lunati voodoo and cranes and comps cams. i think im going to go with the voodoo cam unless i find another i do still have awhile till i get to do this. i didnt know about the EGR delete i will do that when i port the intake is there anything else i should look at doing thats not crazy expensive?
Old May 30, 2015 | 09:09 AM
terry82's Avatar
terry82
put in new valve seals and rocker arms.
Old May 30, 2015 | 10:24 AM
toobroketoretire
Your best performance gain would come from a set of 3.73 gears and with the 30% overdrive of the TH700R4 you'd still end up with a 2.62 final drive ratio. My '82 has a set of 3.54's behind it's TH700R4 but my '71 has a set of 3.70's behind it's TH700R4. Over the years I have found a TH700R4 with 3.73's is an unbeatable combination. Fantastic acceleration along with a very decent cruising rpm.
To crossfire cam question
