I'd trust what I got out of the comp catalog before I'd use the info on Summits site.
Things can change though....give the comp tech line a call and ask them.
AND....you should always trust what Summit writes in their catalogs......FACT! there is no "Chromoly Steel" in a 1020 grade of steel....these are STOCK OEM grade pushrods not what I would use for performance build. You can buy these same pushrods cheaper from Melling Engine parts or other suppliers. Trend is the company who does most of Comp Cams pushrods....OK stuff....if your doing a performance rebuild go with the "Magnum" series or one of the better grades of materials/technology parts from other reputable parts suppliers. Smith Brothers and Manton are other reputable suppliers.
Talked to Comp cam tech for what that was worth. He thought I only needed the Magnum pushrods. Ehh..for an extra $30 I'll get something a bit better.
Short duration cam, but relatively speaking high lift. So I figure inertia forces are pretty high at 6000 RPM on a shorter duration cam with moderate hydraulic intensity vs longer duration with same lift.
