Cut shock mount nut/bolt???
Old Jun 4, 2015 | 08:53 AM
fathernson's Avatar
fathernson
Default Cut shock mount nut/bolt???
hi all. Im soakin my shock mount castle nuts for days now. Oil and hydrochloride acid and heat. I think they will come eventually especially with the acid. But I was wondering has anyone ever just cut the castle nut off with a cutting blade on a 4" grinder? Or would that make it impossible to pound the mount out of the strut?
Old Jun 4, 2015 | 09:31 AM
mortgageguy's Avatar
mortgageguy
Do you mean even the castle nut won't come off?
Old Jun 4, 2015 | 09:39 AM
fathernson's Avatar
fathernson
Yup. Castle nut is seized up.
Old Jun 4, 2015 | 09:49 AM
mortgageguy
Wow! So you would have to cut it right up against the TA support arm. I would hate to see you damage that. Are you sending the arm out for rebuild or doing it yourself?
Old Jun 4, 2015 | 10:03 AM
toobroketoretire's Avatar
toobroketoretire
Using a propane torch heat the nut for about 30 minutes, let it cool, THEN try impacting it off. The high heat will destroy the rust that is holding it on. Better yet would be using an acetylene torch because you can heat the nut cherry red.
Once you get it off be sure to use Never-Seez on the threads or any RTV to prevent rusting in the future.
Old Jun 4, 2015 | 10:28 AM
mortgageguy
Once you get the nut off, I bought a 3/8" pipe cap at Lowe's to screw onto the mount and was able to pound it out. Cost was $1.50 as opposed to $19.50 for the shock mount knocker tool.
Old Jun 4, 2015 | 03:52 PM
BOOT77's Avatar
BOOT77
I had to cut my shock mounts out in pieces but I got my nuts off, so I can't imagine something that rusty being fun. Try a breaker bar with some pipe to extend the handle.
Edit: I did have to cut the castle part off because there was no way I was gonna get the keys out. You'll need new shock mounts if you cut, but you'll prob need some anyway. Also the mounts have a D slot on one end and knurls on the other so don't even try to twist them.
Old Jun 4, 2015 | 10:35 PM
adamdinat's Avatar
adamdinat
Default Nut Splitter
There are tools to split the nut which would reduce the danger of damaging something else. Look up nut splitters. My mount was stuck tight like this. I ended up pulling out the whole trailing arm with the strut attached after working on it for a couple of days with oil and heat. My buddy hit it with the back of an ax and it finally popped. Sometimes it is just a matter of the right leverage.
Old Jun 5, 2015 | 04:15 PM
fathernson's Avatar
fathernson
Good newS ! Muriatic acid acetone mix and a pipe got the castle nuts off.
Now I just gotta pound the darn mounts out!
Think I'll try the pipe cap and back the mount with somethin heavy.
Old Jun 6, 2015 | 04:12 PM
toobroketoretire
Just be sure to coat the threads with a non-hardening gasket sealer or RTV before re-assembling to prevent moisture from getting into the nut.
Old Jun 6, 2015 | 06:58 PM
Red 69's Avatar
Red 69
Heat that nut cherry with an acetylene torch then take an impact wrench to it. Harbor Freight has an electric model on sale for $39 bucks. Buy one and you will never know how you got along without one. Lug nuts come off in short order using this tool, among other uses.
http://www.harborfreight.com/12-in-h...nch-61173.html
Getting the nut off is only part of the chore, then you need to drive the pin out of the strut. It is likely rust welded in place. Don't forget the anti-seize on assembly.
Old Jun 6, 2015 | 10:39 PM
DonnieP73's Avatar
DonnieP73
This might be too late, but you can try what I did. You can go to any
Auto Zone or O'Reilly's and borrow a pickle fork and try driving out the
shock mount. It doesn't cost anything for the loan. You just leave a deposit
and when you return the tool, you get your deposit back.
Get a tie-rod pickle fork not the ball joint.
Here is a shot of how I did mine.
Donnie
To Cut shock mount nut/bolt???
