I need to do some electrical troubleshooting on my 77. It has a mystery battery drain. I found an Electrical troubleshooting guide online for the 1978 model and was wondering if the electrical systems between the 77 and the 78 are close enough to use it.
They should be very similar. What amperage drain are you reading? Have you pulled fuses to narrow down which circuit?
Here is the problem. I have a Fluke multimeter. I also have a 12v test light. My battery is in good shape (actually I have 2 of them).
I installed a fresh battery and the voltage read 12.48v. I checked it periodically all morning and it had dropped to 12.37v. The car started perfectly everytime and when it is running the voltage shows 13.6v to 14.1v. I have a brand new alternator on the car. Anyway... I figured it must have been the old aftermarket radio/antenna booster that was in the car that was causing the original drain (the battery would drain down to not even able to light the dome light after less than 2 hours). I removed the radio and all the wiring for the aftermarket stuff and it appeared that I solved the problem. I went back to the car around 4:00pm and checked the battery with a meter and it was down to around 11 volts and wouldn't even light up the dome light. I couldn't find any draw using the meter or the test light so there was no sense in pulling fuses.
what if you fully charge the battery and disconnect it from the car, what is the reading after multiple hours, if too low you have a bad cell
I tried that first. I also got the battery load tested. I have 2 of them. One is a few years old, the other is a few weeks old. Both tested fine. When I fully charged the brand new one it read around 12.8v. After 3 days of just sitting on my garage floor it was at 12.68v so its not discharging by itself.
The courtesy light timer is a common drain problem.
It is located above the speedometer area. You can bypass it by connecting the white wires on it together.
jgcable, PM me your e-mail and I'll send you a 77 schematic.
Obviously i am testing wrong because my fluke meter doesnt measure amperage. I guess i need to buy an ampmeter.
For a quickie, disconnect the negative cable at the battery and connect the test light between the cable and battery post. With everything off(don't forget the interior light timer delay), the test light should be barely lit, if at all. If it is bright, start removing fuses to try and narrow down the circuit that is being naughty to you.
Then you do not have a power drain....PERIOD. NO light on your test light means NO power going to 'something' that is taking amps out of the battery.
I do not use the test light method myself....even though I have in the past. I got the tool that allows me to see the actual value of amp draw...because repairing all year models of Corvettes...I had to see what the amp draw actually was. Because I have come across many newer Corvettes that start off fine on the amp draw but I can watch my tool and the amp draw increases to the point where it will drain the battery overnight if left connected. And...if I use the test light method on a 1986....the test light will be so bright that you would swear that there is a serious drain...when actually ...there is a drain.... but it is NOT at the point of worrying about the battery going dead overnight or even in a month of sitting. Because the 1984-1996 Corvettes have a drain in the system.
DUB
EUREKA!!!!!!I found the drain. I bought an ampmeter and i started pulling fuses. That didnt work. I then started unplugging things and when i unplugged the windshield wiper motor connector the drain dropped to 0. Now i just need to troubleshoot it.
GREAT...BUT by your last post...no light on your test light is saying you have no power drain...unless it was not connected correctly....meaning not making good contact.
AND....something is 'fishy'...because the wiper is NOT a circuit that should be alive with current with the ignition key OFF....depending on which connector you removed.
What was you ammeter reading before you found the 'drain'????
DUB
3.59 amps with the door closed. 5.39 with the door open. When i pull the connector off of the wiper motor it drops to 0.
I had BAD battery drain in my '80 L48. The last mods I applied, one of them fixed it. First, I replaced the bell housing ground at starter with a new connector. Also, I replaced both starter and solenoid AND new battery. And, I installed a new Kenwood AM/FM/CD deck. I can't say which fixed the problem. However, the C3 can now sit over 3 months and it spins over like it just spent a day on the charger (which now gathers dust under my work bench). I disconnected the analog clock years ago (no improvement). The alternator has not been changed in over 10 years... works fine.
Thanks for the information.
This just does not make any sense due to the wiper motor is a switched part. Meaning that you have to have the key ON in order for it to work...but yet...your interior lights are not switched power. They are hot at all times...like your headlights.
Someone has gotten in this car and messed around.
DUB
It doesn't make sense to me either but I read another thread on this forum with somebody with the exact same problem. There was no resolution on that thread. The only thing I can think of is because there are multiple wires (not just hot and ground) going to the wiper motor maybe one of them is constant unswitched power and that's the wire that is bad.
Your car does not have pulse wipers do they. it should not have them. AND...the black plastic cover on your wiper motor...does is have a single pink wipe coming out of it????
