Clock in74
Old Jun 7, 2015 | 03:55 PM
sheepdawggerry's Avatar
sheepdawggerry
Default Clock in74
I have the console bezel from just installing a new radio. I'm looking to replace the clock that quit it while I have it apart. My question is , how much power should I be get from the battery? Not a lot is coming through, is that normal?
Old Jun 7, 2015 | 04:00 PM
toobroketoretire's Avatar
toobroketoretire
You should be getting a full 12 volts....................
Old Jun 7, 2015 | 07:30 PM
7T1vette's Avatar
7T1vette
The current draw from the clock is very small. The original clock was an 'electro-mechanical' clock that was rewound every 2 minutes (or so) by an electric solenoid. So it was a very short burst of low current every 2 minutes...then nothing till the next rewind.
The most reliable replacement clocks are the quartz-electric type. Very low [continuous] current use...very accurate and very reliable. The original clock was neither.
Old Jun 7, 2015 | 09:31 PM
JimT's Avatar
JimT
Go for the quartz clock - then you are done.......
Old Jun 8, 2015 | 07:20 PM
Paul L's Avatar
Paul L
But if you have a battery disconnect, why bother.
To Clock in74
