1978 headlight issues
Old Jun 8, 2015 | 06:01 PM
Ralph419's Avatar
Ralph419
2nd Gear
Default 1978 headlight issues
Having problems with my headlights, I can get them to go down when vacuum is hooked to base of carb, but they will not go up when the switch is pulled on. Running dual quads so I don't have a vacuum port at the intake. Any thoughts? Thank you. Ralph
Old Jun 8, 2015 | 07:17 PM
Peterbuilt's Avatar
Peterbuilt
The headlights need vacuum to go up or down. Make sure that all of the hoses a hooked up correctly.
How To:
http://www.corvette-101.com/vacuum.htm
Old Jun 8, 2015 | 07:40 PM
toobroketoretire's Avatar
toobroketoretire
If you don't have the hoses plumbed correctly they'll never work right.
Old Jun 8, 2015 | 07:57 PM
Ralph419's Avatar
Ralph419
2nd Gear
Since they go down and not up do you think it is a vacuum issue?
Old Jun 9, 2015 | 04:35 AM
hunt4cleanair's Avatar
hunt4cleanair
There are different types of vacuum and headlamps need manifold vacuum. Typically manifold vacuum pulls 15-18 inches of vacuum while carb ports pull less to manage air fuel ratios.
To 1978 headlight issues
