81 dead as a doornail
Old Jun 8, 2015 | 07:37 PM
bunkle's Avatar
bunkle
Default 81 dead as a doornail
Turned on the ignition to start my 81 and nothing. checked the battery, ok, headlights work, high and low beam. No tail lights, side markers, nothing. Checked the ground, power to the starter, by way of a test light, but no power to the fuse box. Fuses, ok. Still nothing registering on the dash to indicate power. Car is completely original, nothing after market. Ran great when used last. Sat for six weeks, maybe two months, charging it from time to time with a two amp charge to keep the battery up.
Any suggestions or possible causes ?
Old Jun 8, 2015 | 07:54 PM
toobroketoretire's Avatar
toobroketoretire
How did you check the battery? Did you load test it? Are the battery connections nice and clean on the INSIDE? Do you have a good copper engine-to-frame ground cable? If it still has that worthless OEM aluminum ground cable throw it into the garbage.
Old Jun 8, 2015 | 07:59 PM
bunkle's Avatar
bunkle
I checked it with a meter, over the 12volt mark. ( not a great meter, but works )
Has the original ground strap. Everything is cleaned and wire brushed for a good contact.
If the headlights are working and power to the starter, would there still be an issue with the ground?
Old Jun 11, 2015 | 08:43 AM
bunkle's Avatar
bunkle
read other posts with the same advice, change the aluminum ground wire! replaced with a copper ground.
same problem, no power to the ignition switch. How do I check to see if it's the starter mod. is good?
Old Jun 11, 2015 | 10:09 AM
qwank's Avatar
qwank
you may have voltage but the battery might not have enough amps in it to crank the starter. I would try charging the battery before doing anything else.
Old Jun 11, 2015 | 10:12 AM
qwank's Avatar
qwank
checking the starter is easy. first check for 12v at the big cable lug. should be 12v there all the time if the battery is connected. have someone turn the key while checking the smaller purple wire lug for 12v, you should only have 12v when the key is in crank position. if you have 12v there the starter is bad, if you don't you may have a bad neutral start switch or clutch pedal switch if it''s a manual. or an open wire or something else.
Old Jun 11, 2015 | 11:48 AM
LannyL81's Avatar
LannyL81
There are several fuseable links coming off the starter that supplies power to the fuse panel; have you check these?
To 81 dead as a doornail
