vibration
Old Jun 9, 2015 | 11:31 AM
caryb78's Avatar
caryb78
Default vibration
I am getting a vibration that resonates through the car at idle and low rpm. It disappears as soon as you increase rpm above idle/slow speed. It stays gone until rpms come down to that range again and is in a very narrow range of rpm. No noises just the sound from the vibration itself. Any suggestions on where to start looking?
Old Jun 9, 2015 | 02:36 PM
Bjax's Avatar
Bjax
Default vibration
Is it manual or automatic? Could be a host of things from flywheel, clutch/pressure plate, harmonic balancer (damper), just to name a few. I had a similar issue years ago with a manual trans, turned out to be the flywheel in my case.
Old Jun 9, 2015 | 05:34 PM
caryb78's Avatar
caryb78
Default vibe
Automatic, L-82
To vibration
