brake issue
Old Jun 9, 2015 | 06:24 PM
backyardsinger's Avatar
backyardsinger
Default brake issue
1st vette its a 76 only had it a month trying to see what's first.driving home I noticed brakes seem to drag when warm I let off the gas and come to a complete stop without touching the peddle while stoped on a incline put car in neutral and did not roll. all 4 rims were to hot to touch since its all 4 I would assume start with master cyl and bleed? Car has 68k and nothing looks replaced since day 1
Old Jun 9, 2015 | 07:12 PM
rugerm44's Avatar
rugerm44
Sounds like calibers sticking.
Old Jun 9, 2015 | 07:26 PM
blk79nj's Avatar
blk79nj
Congrats on your new ride!
I would run through all the items to make it safe to drive. Brakes, tires, and front end.
Old Jun 9, 2015 | 07:27 PM
toobroketoretire's Avatar
toobroketoretire
Your master cylinder piston isn't retracting and letting the fluid return to the reservoir for some reason. It could be a severe rust-in-bore issue so I recommend taking it apart and looking it over; may need to replace it if the bore is too rusted to hone.
Old Jun 9, 2015 | 08:23 PM
'75's Avatar
'75
Loosen the nuts holding the master to the booster and see if the brakes release.
Old Jun 10, 2015 | 08:26 AM
backyardsinger
Thank you for the info changing master cyl and all brake hoses wheel bearings and seals flushing entire system and see what happens will also check emergency brake to be sure its not grabbing will be a great saturday tools beer and grease nothing better
Old Jun 10, 2015 | 10:18 AM
wombvette's Avatar
wombvette
Before doing all of that try '75 s suggestion.
Old Jun 10, 2015 | 04:16 PM
backyardsinger
What will that tell me? Power booster?
Old Jun 10, 2015 | 07:03 PM
'75's Avatar
'75
It will tell you if the pushrod between the master and booster is too long or adjust wrong.
Old Jun 10, 2015 | 07:40 PM
backyardsinger
Ok thanx i will check it out
To brake issue
