71 Vette Trans question.
Old Jun 9, 2015 | 10:38 PM
HT1663WB's Avatar
HT1663WB
Default 71 Vette Trans question.
In my 71 there is a 350 turbo trans. I know it should have a 400. Any way, the speedo does not work. I checked the cable from the trans to the speedo. No problem, worked fine. I pulled the gear out of the trans it appears to be good. Do the 350 and 400 use the same type speedo gear? Any help would be appreciated.
Old Jun 9, 2015 | 11:19 PM
speedreed8's Avatar
speedreed8
i believe all the gm automatics used the same speedometer driven gear
Old Jun 9, 2015 | 11:53 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Look inside the tailhousing. Sometimes the little clip breaks or the gear just slips on the shaft for the speedo.
JIM
To 71 Vette Trans question.
