Street Demon 625
Old Jun 11, 2015 | 11:30 AM
nivensid's Avatar
nivensid
Default Street Demon 625
For those that are running this carb can you post some pics or descriptions of how the vacuum lines were routed? I am in the process of mounting the carb and appears I have more vacuum lines than ports.
Thanks all....
Old Jun 11, 2015 | 03:40 PM
dembo's Avatar
dembo
1 is a timed vac port, connected to vacuum advance
2 is manifold vac connected to pcv valve (2 ports) and from the pcv valve to vapour canister
3 is a timed vac port which goes to the tvs switch in the thermostat housing (vapour canister purge)
4 is manifold vac. This port is plugged so you need a NPT to hose barb fitting. I use it for brake booster vacuum
There's no fuel vapour vent on the carb, so if you have a 5 port canister the carb vent needs to be plugged on the canister
Vacuum for headlights and heater control still comes from a fitting in the manifold
Nick
Old Jun 11, 2015 | 04:09 PM
nivensid's Avatar
nivensid
Thanks nick that's a big help. Have to find a low profile 3/8" NPT fitting for the headlights and auto transmission. The only fitting on the eldebrock performer intake is right behind the fitting that you used for the PCV and I will have to run a line there. Thanks again for the help.
Old Jun 11, 2015 | 04:45 PM
dembo's Avatar
dembo
My pleasure. I actually swapped out my edelbrock intake for a weiand street warrior because the manifold fitting is further away from the carb, closer to the cilinder head. I couldn't find any fitting low enough to fit under the pcv carb port. Hope you have better luck!
Nick
Old Jun 11, 2015 | 04:56 PM
gdh's Avatar
gdh
dembo, are you pleased with this carb?
Old Jun 11, 2015 | 07:58 PM
nivensid's Avatar
nivensid
Anyone else have any pics of your set up with this carb? Never get tired of admiring everyone's work....
Old Jun 12, 2015 | 06:20 AM
dembo's Avatar
dembo
gdh, it's simple, easy to open, rigid throttle mechanism. I bolted it on and drove after setting the idle. I only have about 100 miles on it. Pulled the plugs recently, they are rather black so it's running rich. Some tuning is definitly required. I do have a starvation issue when i mash the throttle from start or when cruising at a steady pace.
The fuel bowl evaporates less quickly then my quadrajet 2weeks compared to 1 week (95 lead free). when it's filled it starts intstantly hot or cold. Hot start with my quadrajet needed some throttle help. Fuel vapour is better contained, there's no odor except when you put your nose in the venturi.
Nick
Old Jun 12, 2015 | 05:17 PM
gdh's Avatar
gdh
Thank-you, I appreciate your input.
Old Jun 12, 2015 | 05:39 PM
Richard454's Avatar
Richard454
Here's a pic of mine- logged almost 7500 mile on it since last year. Performed great even w/ the tremendous heat this past week on the Hotrod Power Tour.
Saw an average of 15 MPG- and that's w/ 3.55 gears.
Too bad I have a knocking rod- and had to be flatbeded the last 25 of the 2000 mile trip....
However- after rolling off the Flatbed- it started up immediately- knocking like hell- as I drove it up the driveway to start pulling it apart.
Whatever I decide on-whether crate or rebuild- this carb is going back on it!!!
This will make some noise!!!
IMG_01331 by Richard Hayes, on Flickr
Old Jun 12, 2015 | 06:04 PM
nivensid's Avatar
nivensid
Thanks Nick and Richard, with the pics you all posted I should complete my install this weekend.
Old Jun 12, 2015 | 06:24 PM
Richard454's Avatar
Richard454
You are welcome-
I was getting some pics from the Hotrod Power Tour - and I found this one- notice how clean the exhaust tips are after almost 1900 miles.
Should give you an idea of how clean the carb runs-
DSCN5324 by Richard Hayes, on Flickr
Old Jun 14, 2015 | 11:19 PM
nivensid's Avatar
nivensid
Default Installed today
https://www.corvetteforum.com/forums...installed.html
Here is a link to my install today.
To Street Demon 625
