Transmission Problem Solved
Old Aug 17, 2002 | 12:05 AM
StingRayPonyGirl's Avatar
StingRayPonyGirl
Default Transmission Problem Solved
On the suggestion of forum member Killain I bought a new modulator, which turned out not to be the problem :p: , but without his suggestion I wouldn't have come across it. Turns out the metal line leading to the modulator was completely plugged, no amount of air or wire going through would unplug it. Replaced the line, problem solved! I am so thrilled. Still not exactly burning rubber, but I can leave a red light and shift into second before I reach the end of town...before it was shifting at 4500rpm. I've also decided I must only have a three gear transmission. Bummer, unless I haven't gone fast enough at 80 to hit overdrive, doubtful I guess, but even being able to cruise at low speed is a huge improvement over the jumping, roaring monster. Now it's almost a nice dependable ride....unless you count the fact that I got in tonight and only hear clickclickclick, fixed the battery connection and all was well. So, for tonight at least, I am in love again. :)
Old Aug 17, 2002 | 12:12 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Default Re: Transmission Problem Solved (StingRayPonyGirl)
How much was the modulator????????? Did you at least put the new one in while you were there?
Glad she's better.
Old Aug 17, 2002 | 09:29 AM
StingRayPonyGirl
Default Re: Transmission Problem Solved (74-Roadster)
Modulator was only $13, and since we're not actually sure it wasn't causing a problem it got replaced. I'm so thrilled the transmission isn't shot, now I can drive it without fear of messing something up :D I've finally moved up to things like alignment after twelve years.
It doesn't sound very Corvettelike though...very quiet. That's ok, better to hear the next noise. :lol:
Old Aug 17, 2002 | 09:54 AM
PatsLs1vette's Avatar
PatsLs1vette
sure is alot cheaper then a new transmission.at least you got it fixed. :cheers:
Old Aug 17, 2002 | 01:41 PM
vettfixr's Avatar
vettfixr
:lol: I know the feeling. Congrats on the fix.
To Transmission Problem Solved
