Side Pipes on a 77?
Old Jun 18, 2015 | 07:37 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by qwank
I always buy the black headers and strip the paint off of them and recoat with VHT high temp paint. The black paint that comes on them usually burns off after a few hours. The VHT will last a long time on a garaged car that doesn't get driven everyday.
That's what I thought, and what I did, when I bought a set of the Hooker side headers, for a Trans Am I owned back in the late 70s. Unfortunately, that theory didn't hold up, as dirt kicked up by the front tires, effectively "sandblasted" the paint off the pipes on a regular basis, eventually causing the pipes/collectors to rust out and fall apart.
I'd go either chrome, or powder coated black.......Just my $0.02 worth.
Old Jun 18, 2015 | 08:00 AM
binster's Avatar
binster
Fyi. This will give you the feel for factory covers that are painted black
Old Jun 18, 2015 | 09:10 AM
jgcable's Avatar
jgcable
Beautiful car. If mine was a collectors item or show quality I would spend the $2500 for side pipes like those but my car is an unrestored car that is rough around the edges. Its a driver. I am practically sitting on a milk crate to drive it!
Old Jun 18, 2015 | 09:20 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Headman makes a set of headders that exit to the sides instead of to the back. This helps with the pipe routing, no 180 turns, that could be hooked up to the 69 style pipes or look at the Patriot 4 into 1 look with the single inlet. Shorties are also an option. Although they are sold in chrome, you can paint them with VHT black for the look you want. Reasonable cost and great sound. My photo album show several pics with the Patriot pipes. I ran them for years till recently when I installed the original style that ny car came with. Its your cruiser, make it your own.
Old Jun 18, 2015 | 10:12 AM
leadfoot4's Avatar
leadfoot4
I believe those Hedman Hedders that you refer to, are made expressly to be connected to the factory side pipes...
Old Jun 18, 2015 | 12:59 PM
qwank's Avatar
qwank
I have under $800 invested in mine. that includes headers, pipe, baffles, paint and covers.
Old Jun 18, 2015 | 01:05 PM
qwank's Avatar
qwank
those are the ones I have. I made my own pipes.
Old Jun 25, 2015 | 10:03 AM
jgcable's Avatar
jgcable
I have been back and forth between the true 2.5" dual exhaust system and a set of side exit headers and side pipes. Cost is a factor of course but I think I can come up with an inexpensive system. I just want a set of black side mount headers and black side pipes. They don't need covers on them and I will start off running them without baffles unless they are too loud and then I will add them. Summit has a set of Hedman sidemount headers for $199.97 shipped. The problem is I can't find a set of black side pipes that will work with them. Hooker makes a system and so does Dougs but they are both too expensive because Hooker and Dougs charges $550 for their side mount headers. I would like to get the black headers that have the tabs on them that make it easy to mount them to the car. I figure that after all these years I finally have the car of my dreams and I always pictured it being loud with black side pipes on it. I won't be happy unless I get them. Has anybody here used the Hedman 68280 side mount headers? If so... what side pipes did you run with them?
Old Jun 25, 2015 | 12:50 PM
qwank's Avatar
qwank
did you not see my post right above yours? those are the Hedman 68280 headers
I suggest you buy the Hooker kit kit though, sounds like that's the style you really want.
Old Jun 25, 2015 | 02:07 PM
jgcable's Avatar
jgcable
Yea, I see that you made your own pipes.
So from it looks like in the pics... the Hedman side mount headers exit straight out the sides of the car and in order to attach them to side pipes there additional pipes and turns involved and the Hooker and the Dougs side mount headers exit towards the rear so the side pipe just clamps on to it straight which looks like a much cleaner set up. Also.. the Dougs and Hooker headers have the actual header pipes exposed at the rear of the front wheel openings. That's definitely what I am looking for.
Now... the decision is Hooker or Dougs. The Hooker system without baffles is $820 Dougs system without baffles is $800
Old Jun 25, 2015 | 02:11 PM
qwank's Avatar
qwank
you could also buy this stainless steel set up and spend $15 on VHT black paint for the same price.
http://www.ebay.com/itm/Maximizer-Exhaust-Header-Resonated-Side-Pipe-Corvette-C2-C3-Stingray-SBC-V8-/161711330008?fits=Year%3A1981%7CModel%3ACorvette&hash=item25a6bf12d8&vxp=mtr
Old Jun 25, 2015 | 08:23 PM
Ibanez540r's Avatar
Ibanez540r
Originally Posted by wendellp601
I just got these delivered today for my 1977 from Summit.
I went with black, too.
The brackets are not needed. They come with the pipes.
Old Jun 26, 2015 | 10:26 AM
  #33
nivensid's Avatar
nivensid
Maximizer Exhaust Header Resonated Side Pipe Corvette C2 C3 Stingray SBC V8 | eBay
I have these in stainless and before that I had the aftermarket 69 style. Here are some pics of both on my 78 for comparison.
Old Jun 26, 2015 | 12:08 PM
  #34
JD77's Avatar
JD77
Lastly... how high up does the car need to be on jackstands in order to fit the headers in from underneath?
I can answer this, as I've been putting Doug's Headers and Side Pipes on my 77 the last couple days. I've got my car jacked up about 16 inches and was able to get the headers in with a little wiggling. The instructions said 3 ft and I've seen 2 ft elsewhere, but you can do it with less.
Ideally, having the car on a lift would be preferable.
Old Jun 26, 2015 | 12:41 PM
  #35
qwank's Avatar
qwank
headers slide up into these cars fairly easy
Old Jun 26, 2015 | 01:44 PM
  #36
jgcable's Avatar
jgcable
Thanks for the reply. I have 4 heavy duty jack stands and a nice floor jack so I will be using them. I have a few questions for you if you don't mind since I am a new Corvette owner.
What was your procedure for jacking up the car that high and where did you place the jack stands? Did you use 2 jack stands or 4?
Did you support the nose and if so.. from where?
Is there a particular reason you chose Dougs over Hooker?
Old Jun 27, 2015 | 10:04 AM
  #37
JD77's Avatar
JD77
I'm not sure if I did it the best way and I know the old hats will speak up if there's a better way. I placed the rear jacks in front of the rear tires under the frame. The front jacks I placed under the frame in front of the tires and more under the engine. I used 4 jack stands (3 ton). If you do some google searches of installing side pipes, you'll find some forum threads in this forum and others with pics showing the process. Good luck!
Old Jun 28, 2015 | 09:56 AM
  #38
HT1663WB's Avatar
HT1663WB
When I had my 77 (4 speed) I wanted side pipes but couldn't decide on which set up. I bought both sets, had the covers painted black at a friends body shop. I ended up going with the Hookers. But the black set bolted right to the manifold just did not have the same sound as the Hookers.
Old Feb 5, 2018 | 11:51 AM
  #39
Darryl1976's Avatar
Darryl1976
Cruising
qwank to use the hedmans, what angle did you have to bend the pipes to? I'm going to be buying angles to weld my side pipes together but I can't tell from pictures. 60°?
