I have a small amount of rust accumulating on my carburetor for my 78 silver anniversary edition L82. I want to replace the original with a performance one. Besides the carburetor, what other performance upgrades would you suggest? The entire engine was rebuilt in 2011.
A "performance carburetor" isn't going to make a difference on a 78 L-82. Have your original quadrajet rebuilt by Lars and your car will be just fine. it's already more carb than a stock L-82 can use.
How was it rebuilt in 2011? Back to stock? If so, just add some headers and true dual exhuast and be done with it. Otherwise you'll need to upgrade the heads/cam, intake manifold, compression, etc..
you will devalue the vehicle, keep the original and rebuild it.
how your motor was built determines your power.
just throwing a big shiny carburetor on is wasting money.
As everyone else has said you won't go wrong with the Qjet.
Thanks everyone. So it looks like I should just clean up the small sections of rust and keep it all original. As for headers and exhaust, what do you all recommend? I was just given this vette from my grandfather who bought it off the lot in 78, so I don't know a ton about it yet besides that he did get the engine re built in 2011. I want to keep it pretty darn original, but get some more power.
Biggest gain power to dollar is to tune the distributor with a quicker advance curve and give it full timing (36* is what stock L-48s typically like at ~2500 rpm).
Long tube headers (1 5/8") and a good dual exhaust system will wake it up too.
You have a cool car given to you by your Grandfather. Why would you want to start throwing money at "go-faster" parts that won't make it go any faster?
Leave it alone, take care of it properly, and enjoy it.
you should figure out what your engine was rebuilt with ? Stock 1978 low hp motor.
you need to know what parts are original, or not.
without knowing this information, I would suggest leave it as is.
my best advice, research and figure out exactly what you have for a motor.
specially the pistons, heads, intake, carb. dist. maybe Cam info?
Since you asked what is a good performance carb I will answer Holley. But the other posters are correct it will not make you faster if nothing else is changed. First question to ask is how much can you afford to spend. Get that amount and you will get plenty of contradictory advise on how to spend it. It's not how fast you want to go it's how much can you spend. Remember in wading through the advice it is all opinions there is no one correct answer.
You will need a square bore manifold, headers and a carb to approach 200 hp. And lose the smog stuff.
Although you are undoubtedly not surprised - I disagree.
Headers will get you there. Don't even need to lose the smog stuff - although life would be much easier not having to deal with it.
How do I know? I've lived this. My 78 'vette went through a battery of testing from its initial configuration (0-60 in low 8s) all the way up to the previous engine iteration.
I can't remember the figures now, I've posted them in the past, but distributor tuning got my 0-60 time into the low 7s and headers took me to the mid 6's, 6.5 if I remember right - and that *matches* the L-82 numbers. Yes, the L-48 is higher on torque due to cute valves and a bumpstick that barely moves them, but I've little doubt that car was making 210-220 hp in that configuration.
To really move much past that, though, you get into cubic dollars. Vortec heads and a mild cam will take you well into the 300 hp range, and the $$ numbers get bigger from there...
