Removing Rear crossmember
Old Aug 17, 2002 | 06:06 PM
Lohkay's Avatar
Lohkay
Default Removing Rear crossmember
Hey guys, I'm trying to remove the read crossmember and it won't buldge...differential carrier is removed and I removed both nuts on each sides...is there something else I should do? The bushing is kinda weird but I'm not sure its that. I tried to pry it off but it doesn't give at all...I must be missing something but I really don't know what.
Old Aug 17, 2002 | 06:26 PM
Juliet's Avatar
Juliet
Default Re: Removing Rear crossmember (Lohkay)
Sounds like you need a bigger pry-bar. Those bushings are rubber and really wedged in there. It took quite a bit of work to get the rear X-member off my '70. It also had the weight of the differential still on it helping along. ~Juliet
Old Aug 17, 2002 | 07:20 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Removing Rear crossmember (Juliet)
Those things are a #^$%^$# t get off. When I had mine torn a part I had a 350 Pound friend hanging off a three foot pry bar, and it still took a lot of time and effort to get it off. We were lifting the front end of the car off the rack from all the weight we were putting on the rear to get it off.
Get out the penetrating oil and keep working on it.
Old Aug 17, 2002 | 07:41 PM
67HEAVEN's Avatar
67HEAVEN
BE CAREFUL. When it lets go, there lots of weight looking for the floor (especially if the diff is still attached)!!! :eek:
A pry bar is the secret. It will come loose. Leave one side bolted up tight and pry the other side (with that bolt loosened to the last few threads).
When one side is loose, tighten up the loose bolt a bit (to get a few more threads) and then loosen opposite bolt and pry again.
Be careful of the weight.
Old Aug 17, 2002 | 10:00 PM
Lohkay's Avatar
Lohkay
Default Re: Removing Rear crossmember (67HEAVEN)
wow....damn bushings heh? :D Gonna try it tomorow with a bigger pry bar.. (had a 2 foot one). I'll keep u guys updated.
Old Aug 17, 2002 | 10:05 PM
67HEAVEN's Avatar
67HEAVEN
By the way, Lokay, careful of the large rubber cushions (about 4.5" diameter). Don't damage them if you can avoid it.......for two reasons.
1. They're a brute to remove from the crossmember and hard to reinstall if you damage them.
2. They're EXPENSIVE.......approximately $US70.00 each!
Old Aug 17, 2002 | 10:25 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Beware of gravity.
Old Aug 17, 2002 | 10:33 PM
78Vette-SA's Avatar
78Vette-SA
Leave the bolts partway on so it doesn't go flying when it gives way.
It took a crowbar and a 5lb hammer and lots of whacks to get mine off but finally gave way.
Old Aug 17, 2002 | 10:48 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Removing Rear crossmember (78Vette-SA)
I bought a 5 foot pry bar, and it was still hard!
And keep the bolts on a little!
Old Aug 17, 2002 | 10:53 PM
NHvette's Avatar
NHvette
Default Re: Removing Rear crossmember (427V8)
Am I the only one that got them off without getting a hernia ?
I took mine down during th efirst month of ownership, but I don't
remember having a problem. Guess I got lucky.
:seeya
Old Aug 17, 2002 | 11:46 PM
Jack71's Avatar
Jack71
Default Re: Removing Rear crossmember (Daves_rusty_75)
It shoots off like cork out of a champaigne bottle...
I second the 5 ft pry bar.
I kept my jack about an 1/8 inch below the diff. When it breaks loose, the bushings won't clear the mounts.
Old Aug 18, 2002 | 12:18 AM
LT1driver's Avatar
LT1driver
good advice by all, I did it the easy way on a 67, had the body off :D :D good luck :cheers:
Old Aug 18, 2002 | 11:27 AM
Tom Johnson's Avatar
Tom Johnson
I used an electric heat gun on my 71.
To Removing Rear crossmember
