Boiling in Radiator?
Old Aug 17, 2002 | 08:05 PM
dsagers's Avatar
dsagers
Default Boiling in Radiator?
If I drive the Vette until it's fully warmed up, within a few minutes after parking it the radiator sounds like it's boiling?
Temps while running are normal, belts are tight, coupler on the mech fan is working.
What causes the boiling?
Old Aug 17, 2002 | 09:14 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default Re: Boiling in Radiator? (dsagers)
is it full? correct antifreeze/water mix?
Old Aug 17, 2002 | 10:04 PM
mrvette's Avatar
mrvette
It's not in the radiator, probably the heads, it' just radiates the sound to the rad through the water....
gut the t-stat, and see if it stops...need the restrictor plate in position..but gut the thing....temps in the engine are too high...
bet that cures it...need put another stat in come winter though...
GENE
Old Aug 17, 2002 | 10:46 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Boiling in Radiator? (mrvette)
It could also be the radiator sucking coolant back intoitself from the overflow, kinda a gurgleing sound...
Old Aug 18, 2002 | 12:12 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Default Re: Boiling in Radiator? (Markm10431)
Raising the pressure on any liquid will also raise the boiling point. If your coolant system has a leak or a bad radiator cap you may be losing the pressure, allowing boiling to occur. I will echo what someone else said, the boiling is not occuring in the radiator, probably just being heard from there, as sound travels through the thin material much easier than through the cast iron block, etc. A simple pressure test of the coolant system may help solve the problem.
To Boiling in Radiator?
