Smelling gas
Old Jun 22, 2015 | 11:35 PM
Boatz4life's Avatar
Boatz4life
5th Gear
Default Smelling gas
I smell gas when I'm at a stop or when I turn on the AC.
Old Jun 22, 2015 | 11:39 PM
Boatz4life's Avatar
Boatz4life
5th Gear
Sorry guys. It's a 81. All stock no mods at all. The car did sit for 9 years also.
Old Jun 23, 2015 | 01:38 AM
BOOT77's Avatar
BOOT77
Does your fuel have 10% ethanol? If so google
Old Jun 23, 2015 | 11:21 AM
MelWff's Avatar
MelWff
did you check under the hood for a gasoline leak?
Old Jun 23, 2015 | 11:36 AM
hugie82's Avatar
hugie82
Looking around for a leak is the first thing you should do. All down the passenger side. If it happens only with a full tank, look down the drivers side. There's a small 1/4 line running from the charcoal canister under the washer fluid bottle. That is the vent for the gas tank. They often rust out and any liquid fuel entering the line usually drips a little giving off the fuel odor. I never fixed mine but I don't top the tank off like I use too.
Old Jun 23, 2015 | 05:28 PM
clwi's Avatar
clwi
Check the fillerneck seal, mine smelled also, get a new thicker seal, problem solved for me.
Old Jun 23, 2015 | 08:53 PM
BLUE1972's Avatar
BLUE1972
Check the gas cap seal.
Check around the carb, fuel line for leaks.
To Smelling gas
