Gas smell inside cab
Old Jun 23, 2015 | 11:56 PM
Reddytogo's Avatar
Reddytogo
2nd Gear
Default Gas smell inside cab
When ever I drive my 76, I smell gas in the car, I don't know why, any help will b appreciate.
Old Jun 24, 2015 | 08:31 AM
bashcraft's Avatar
bashcraft
Baked beans can cause this...
Old Jun 24, 2015 | 11:48 AM
GRipp 73's Avatar
GRipp 73
I see you are a new member Reddytogo. Welcome!
First, is this a new to you 76'? Have you ever driven a car with a carburetor before? The smell of some gas is normal as it is an open system, but it shouldn't be enough to make you dizzy or anything serious like that.
What state is your Corvette in? Is it ready for some TLC? Give us some more details...
Old Jun 24, 2015 | 12:29 PM
ddawson's Avatar
ddawson
Smelling while driving would be leak. It will smell after parking in the garage after a drive.
I smell that stays strong after a few hours parked would also be a leak.
The rubber lines go bad from the inside but will show cracks if you squeeze them.
Old Jun 24, 2015 | 03:28 PM
Jazzyced's Avatar
Jazzyced
Replace all the rubber lines (including the ones between your tank and the steel lines).
It cost next to nothing and will give you some peace of mind.
You don't know what the PO did before you...
I have a 76 and in the last 3 months I replaced the rubber line between the pump and carb twice already. The 1st time was because of some very old crumbling lines, the 2nd was my fault as I kept on disconnecting it to play with the carburetor. The leak was a sneaky one: the clamp dig into the rubber and the leak was only visible when a bit of pressure was applied onto the line...
After replacing the lines, the gas smell in the car almost disappeared and the garage does not smell like a petrol station anymore...
Old Jun 24, 2015 | 08:27 PM
doctorgene's Avatar
doctorgene
My 77 had the same problem, I replaced the sending unit gasket on the tank & also the hoses. Use Fuel Injection hose, which they claim will stop the deterioration of the new EPA gas eating the hoses. It is a little more money, but what the Heck. Gene
Old Jun 24, 2015 | 08:56 PM
yyz1970's Avatar
yyz1970
Your leaking! check it out before the fire dept is called
Old Jun 25, 2015 | 04:56 PM
clwi's Avatar
clwi
Check your filler hose neck gasket, i replaced mine for a thicker one and problem solved!
Old Jun 25, 2015 | 11:06 PM
Msbfdx's Avatar
Msbfdx
Check fuel pump and roll over check valve on top of gas tank.
To Gas smell inside cab
