What can I do with high compression?
Old Jun 21, 2015 | 03:12 PM
ScottieS's Avatar
ScottieS
Default What can I do with high compression?
My sbc engine runs at about 11:1 right now and from what I've read it seems useless to put a low boost turbo or a supercharger.
I'm already running high compression forged Pistons etc etc.
What have you guys done with your high compression engines?
Old Jun 21, 2015 | 03:57 PM
7t9l82's Avatar
7t9l82
I'm not seeing what your trying to do, 11.11 compression isn't a problem unless your adding boost.
Old Jun 21, 2015 | 04:07 PM
toobroketoretire's Avatar
toobroketoretire
If you want to put a blower or turbocharger on it you'll have to lower the compression ratio to around 8 to 1 because an 11 to 1 would cause detonation under much boost.
Old Jun 21, 2015 | 05:46 PM
bmans vette's Avatar
bmans vette
St. Jude Donor '12-'13, '15- '16-'17-'18-'19, '21
Identify your objective and then build your engine accordingly.
High compression engines are old school and usable with high octane gas and low mpg. Which was the 50-60-70's.
Nothing wrong with that. I grew up old school and love it.
But if you want new technology you will have to change the bottom end of the motor.
Or just go LS swap and sell/save the high compression engine.
IMO
Good luck
Bman
Old Jun 21, 2015 | 10:20 PM
bluedawg's Avatar
bluedawg
Run high dollar fuel or change pistons.
Old Jun 21, 2015 | 11:34 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Some further engine specs would be helpful. What's cam look like?
You can easily run 11 to 1 if the rest of the engine is right.
Old Jun 22, 2015 | 11:17 AM
bluedawg's Avatar
bluedawg
From the sounds of his post, it sounds like the op wants to go forced induction.
Old Jun 22, 2015 | 11:38 AM
C3_ERROR's Avatar
C3_ERROR
Spray the crap out of it if you want more power. FI isn't an option really unless you lower the compression. A thicker head gasket can lower the compression but it isn't going to get you to 8 to 1. Maybe 10 to 1.
Old Jun 22, 2015 | 11:49 AM
bluedawg's Avatar
bluedawg
I didn't think of this before, but maybe on e85.
Old Jun 22, 2015 | 11:53 AM
claysmoker's Avatar
claysmoker
I got that, but who knows when we don't hang all the laundry out for everyone to gawk at?
Old Jun 22, 2015 | 06:47 PM
7t9l82's Avatar
7t9l82
Since when is 11-1 compression old school a lot of the new performance engines are 11-1 from the factory and with aluminum heads will work on pump gas..
I agree if adding boost is the plan you are probably looking g at a piston swap.
Old Jun 22, 2015 | 07:48 PM
bashcraft's Avatar
bashcraft
And they have a computer...
Old Jun 23, 2015 | 01:21 AM
bmans vette
I think you misread my comment or I was not clear enough.
He has a sbc with 11-1 cr and wants to run boost.
Most people know that is too high to safely run boost without some other precautions to prevent detonation.
Like aluminum heads or higher octane fuel.
He did not say he had either.
And I know that 11-1 cr engines are coming off the present assembly line. But how many are running boost?
As to old school comment - I said HIGH compression engines. Back in the 60's we ran 12.5-14 to 1 cr in many of our sbc. Most of the time with modified iron heads and sunoco 260. Nowadays we have easy access to aluminum heads but you need practically racing fuel to get the octane we could buy on the street.
That is the old school vs modern day comparison.
If this guy is asking these kind of questions, it is obvious that he does not have a LOT of experience in this area.
Telling him to go ahead and run boost on a 11-1 engine without other information like heads, cam specs, head gasket thickness, age of motor, etc.....is setting him up for a possible detonation.
That is all.
Better informed than to find out the hard way.
Bman
Old Jun 23, 2015 | 07:01 AM
tektrans's Avatar
tektrans
Just run c-16 if you wanna run boost and 11:1
Old Jun 23, 2015 | 09:34 AM
C3_ERROR's Avatar
C3_ERROR
It would be cheaper to replace the pistons than a years worth of C16. Maybe e85 and a water/meth spray kit but even thats limited.
The OP really only has 3 choices.
1) keep the motor like it is and use n02 for more power.
2) replace the pistons for a lower CR.
3) Sell/trade the motor for a motor with lower CR.
Even if running boost on an 11 to 1 was done you couldn't run more than a few psi (like 4 and pushing it would be 6) and not worth all the time and money you would spend on a turbo or S/C.
Personally if I would going to run a boosted motor I would just drop in an LS1/LQ4/LM7 motor and boost the snot out of it.
Old Jun 23, 2015 | 01:10 PM
7t9l82's Avatar
7t9l82
It may require larger chamber heads too, depending on how it's built.
Old Jun 23, 2015 | 08:56 PM
BLUE1972's Avatar
BLUE1972
Talk to your local engine builder and run E85 with boost..
To What can I do with high compression?
Old Jun 24, 2015 | 12:40 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Spray it and get a timing retard box that activates when the NO2 does. No problem. Need approx. 2 degrees per 50 HP and tune from there. It helps to run a real high octane race fuel in a dedicated nitrous tank if you spray hard. Read plugs to tune.
Old Jun 24, 2015 | 06:53 PM
labhound's Avatar
labhound
Burnouts.........
Old Jun 25, 2015 | 11:10 PM
7T1vette's Avatar
7T1vette
We don't even know if he has aluminum heads (or not). Tough to run 11:1 CR on iron heads with the cr@p fuel available today.
