72 Decoding - "help please"
Old Aug 18, 2002 | 09:52 AM
C2 Karl's Avatar
C2 Karl
Default 72 Decoding - "help please"
I just purchased a 72 Corvette coupe (my first) and would like some help to decode the following:-
VIN# 1Z37K2S511885
Engine manuf.# V0912W1
Diff# LRW010E1
Unfortunately I bought this car less the trim tag which was lost by the painter who removed it for painting. I can confirm that the partial VIN number on the motor & gearbox match the vehicle. Is there a way of confirming the trim tag details without having the build sheet (could not find a tank sticker etc.)?
Thanks, Terry
PS. I am using my brothers user name if you are wondering about the C2karl?
Old Aug 18, 2002 | 10:27 AM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Re: 72 Decoding - "help please" (C2 Karl)
Good Luck wih your new72. Your Vin number indicates that you have a 72 coupe with a base 350 [200 hp] manufactured in Jan 72. Your engie code indicates that t is not the engine form your car. To determine what rear in thecar you need a 2 alpha codesuch as AX [3.36]
Ed
Old Aug 19, 2002 | 04:00 AM
LT1driver's Avatar
LT1driver
Default Re: 72 Decoding - "help please" (ED DINAPOLI)
Terry, your rear is a 3.36 as indicated by the LR, the w is part of the other numbers, just checked my ncrs book, have fun. Hope there is no problem without a vin plate, big pain here in texas without one. :cheers:
Old Aug 19, 2002 | 07:31 PM
Tomi72's Avatar
Tomi72
Congrats on your purchase Terry! I noticed that your car is about 100 units newer than my -72, probably built the same or following day :cool:
Regarding the trim tag info, I haven't heard that it could be verified anywhere else than the build sheet. The build date on mine is F19 ( jan 19th ) so I presume yours could be the same.
rgds Tomi
To 72 Decoding - "help please"
