Ground?
Old Jun 26, 2015 | 11:03 AM
skip99202's Avatar
skip99202
Default Ground?
72 4 spd coupe.
I assume this is a ground, where does it connect? only long enough to reach shifter console?
Old Jun 26, 2015 | 11:19 AM
mysixtynine's Avatar
mysixtynine
Yes that is a ground.
Yes it would go to something on the shifter plate.
I have seen on my 69 that it goes to one of the screws that hold the ash tray door in. But I have also seen (I think on AC cars) that it goes to a tab on the heater/ac controls.
I put in an aftermarket cigarette lighter in my car with the light and it had a tab for the ground wire so I just put it on that instead of the plate as it is really only there for the cigarette lighter in my car. I ran additional separate grounds myself to the tunnel brace, wiper switch etc.
Old Jun 26, 2015 | 11:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by mysixtynine
...Yes that is a ground....Yes it would go to something on the shifter plate...
Look for a spade terminal on the underside of the console plate, possibly near the upper left corner of the ash tray opening.
Old Jun 26, 2015 | 01:57 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Easy Mike got it same on my car(68) skip.
When you flip over the shift console there will be a brass spade.
usually you can reach through the ashtray and reattach if my memory serves me.
It a ground. I saw it when i removed mine to replace the beat up shift boot.
Thanks for the help on the headlight thread again.
Still working on the problem
Marshal
Old Jun 26, 2015 | 02:32 PM
skip99202's Avatar
skip99202
Ok thanks!
I have all new shift console and ebrake console, it was all gone...not as easy if you didnt take it apartyourself!
To Ground?
