Motor Support while changing mounts
Old Jun 27, 2015 | 11:55 PM
mijohnst's Avatar
mijohnst
Default Motor Support while changing mounts
I've been doing some work around the engine (thanks for the support from you all) and now it's time to get to the motor mounts.
If I gas my C3 too much, the fan hits the shroud. After inspecting, I think the mounts are original. I don't have a cherry picker and I'm trying to decide how I'm going to support the engine safely. Some videos show people putting wood under the oil pan and lifting the engine about an inch but I'm really nervous about doing something like that. Anyone have a recommendation?
Old Jun 28, 2015 | 12:39 AM
BOOT77's Avatar
BOOT77
Loosen both, but only do one at a time and use the wood block & jack method. I did both that way, it's not gonna fall out.
Old Jun 28, 2015 | 01:43 AM
mijohnst's Avatar
mijohnst
To verify, you mean using the wood block and jack under the oil pan, right?
Old Jun 28, 2015 | 02:02 AM
BOOT77's Avatar
BOOT77
Yes and I meant the main mount to frame bolt you loosen, not the mount to block bolts.
Old Jun 29, 2015 | 12:50 AM
mijohnst's Avatar
mijohnst
Thanks very much for the advice! Worked perfectly. The only issue that I had was when I installed the new one. I put the long bold through first before bolting the three in the block first and the holes wouldn't line up. It took me about an hour and 2000 swear words before I figured out the correct order. Live and learn I guess. Thanks very much for the help.
Old Jun 29, 2015 | 02:22 AM
BOOT77's Avatar
BOOT77
NP, I've learned a lot from this forum and gotten good advice on stuff myself so I always try and help out where I can
Old Jun 29, 2015 | 09:14 AM
mijohnst's Avatar
mijohnst
I agree. This is a great collection of people here. ALWAYS helpful!
Old Nov 24, 2019 | 04:40 PM
RBF59's Avatar
RBF59
3rd Gear
Default Replacing an oil pan in a 08 Corvette convertible
I'm trying to find out the truth on how much work it is to replace the oil pan in my 08 Corvette. I've seen more people have jacked up the engine a little bit too get the screws loose and oil pan out. Without removing the entire front suspension and cross arm support. Can anybody tell me the correct and most cost-effective way to do this project?
THANKS,
Rick
Old Nov 24, 2019 | 05:13 PM
BKbroiler's Avatar
BKbroiler
THANKS,
Rick
08 Corvette? You need to post this in the C6 Forum. This is C3.
To Motor Support while changing mounts
