Drive Shaft Orientaion
Old Jun 29, 2015 | 08:30 PM
Sky65's Avatar
Sky65
St. Jude Donor '05, '09, '15
Default Drive Shaft Orientaion
Hello. I have a modified 65 that I have a C3 drive shaft for. It is larger in diameter than a C2 shaft and used larger u=joints. The shaft I have is bare...no joints. Is it directional? Have a front and back? Looks the same on both ends.
Tom
Old Jun 29, 2015 | 10:36 PM
BOOT77's Avatar
BOOT77
I mark the slip yoke to shaft orientation to any shaft I take apart with paint to try and keep the balance the same. You could just take it and your yoke and have them balanced then paint a spot on both so it won't be mixed up. Or just throw it on and if it vibes flip ends and see if it's any better, that is if each end uses the same u-joints.
Old Jun 29, 2015 | 10:40 PM
bashcraft's Avatar
bashcraft
Tom
It doesn't matter. Put in in however you like.
Old Jun 29, 2015 | 10:45 PM
Sky65's Avatar
Sky65
Thanks guys. That's what I thought.
Tom
Old Jun 30, 2015 | 09:35 AM
Aggitated Monkey's Avatar
Aggitated Monkey
Take it to a drive line shop and let them balance it. I had mine done. Two spicer U joints, shortened 3" for a 700r4 and balanced for less than $150
Old Jun 30, 2015 | 09:56 AM
bashcraft's Avatar
bashcraft
If it's not being shortened, what reason would there be to have it balanced?
Old Jun 30, 2015 | 10:22 AM
Aggitated Monkey
I like to balane for peace of mind. Its only $50 to balance and you will be certain that any vibe after the build is not the drive shaft. LOL...maybe it's just my 42 years of Aviation.
Old Jun 30, 2015 | 06:23 PM
bashcraft's Avatar
bashcraft
My 25 years of Engineering would tell me to spend that $50 on something else.
To Drive Shaft Orientaion
