Replacing AC Hoses when converting to R134
Old Jun 29, 2015 | 09:16 PM
mark79,80's Avatar
mark79,80
Default Replacing AC Hoses when converting to R134
When converting to R 134 on a 1980 Corvette should the compressor hose assembly be replaced? The existing hoses look to be in good condition and the car only has 24000 miles. Secondly, what is the best orifice tube to use?
Old Jun 29, 2015 | 10:01 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
From what I've heard is that it is better to keep the old hoses because a new R-12 hose will leak with R-134. I use a Ford blue orifice tube.
Old Jun 29, 2015 | 11:27 PM
rebel542's Avatar
rebel542
I agree with bruiser. I used the original lines and a Ford blue orifice tube. 42 degrees out of the center vents on a 100 degree day with 134a.
Old Jun 30, 2015 | 07:48 AM
jnealg's Avatar
jnealg
We use the white GM tube but if the blue one works for these guys it should be fine. the original hoses, if in good shape, will be fine. just check for bubbling or leaks when charged up.
To Replacing AC Hoses when converting to R134
