Removed and weighed heater
Old Aug 18, 2002 | 05:32 PM
Blues77's Avatar
Blues77
Default Removed and weighed heater
For you on a diet. I weighed with my digital scale, which is pretty close. Without the water, including the hoses, lost about 35-40lbs. Alot more room in engine compartment, and under dash.
Old Aug 19, 2002 | 04:15 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Removed and weighed heater (Blues77)
Is this just a heater and no air? I used this space for my electronics. 4 msd system components, a coil, a remote starter solenoid and a whole bank of relays. I remove my passenger panel and everything is right there.
Old Aug 19, 2002 | 05:05 PM
Blues77's Avatar
Blues77
Default Re: Removed and weighed heater (norvalwilhelm)
The condensor was on there, which is around 5lbs.
I had the same planes on putting MSD and other goodies in the unused area. Theres now nothing under my dash :D . Heater sure takes up ALOT of space..
Old Aug 19, 2002 | 05:11 PM
Fevre's Avatar
Fevre
Just don;t get caught out on a cool evening without it. Not being able to see through a fogged windsheild can be fun but still dangerous. :eek: Only reason I kept mine.
Old Aug 19, 2002 | 05:15 PM
Blues77's Avatar
Blues77
NEW: I just weighed stock Iron intake manifold. 41 lbs!!!
Compared to performer's 14lbs.
Iron water pump and fan = 19lbs
Iron caliper = 10lbs
I have more stuff to weigh, Ill post updates here
Edit: Fevre- That was my hesitation. It didnt work anyway. Ill just crack the windows if it fogs, or tell the passenger to blow on the windshield.
[Modified by Blues77, 3:17 PM 8/19/2002]
terryrudy's Avatar
terryrudy
Have any pics? Wondering how big of a job this is. Any write-up for Corvettefaq? ;)
Anyway, sounds cool. Something I am considering.
-terry
Old Aug 19, 2002 | 05:43 PM
The Dude's Avatar
The Dude
Front anti-sway bar, bushings and end links (FE7) = 13.5 lb.
Steel Rallye wheels w/derby caps and trim rings = 51 lb. each.
Old Aug 19, 2002 | 06:57 PM
Schwee's Avatar
Schwee
Default Re: Removed and weighed heater (The Dude)
Fat chick in the front seat: 225 lbs.
Old Aug 19, 2002 | 07:23 PM
bsowa's Avatar
bsowa
Default Re: Removed and weighed heater (Schwee)
LMAO
To Removed and weighed heater
