Can upper control arms be reversed upon installation.
I'm doing a body off resto on a 75' coupe and have noticed that the caster camber is way off after reinstalling the upper and lower control arms. They were perfect before the resto and all the upper and lower bushings were replaced. I tried to replace the shims in exact order but after adding even more shims (3-4 in total) it's still way off. See image below.
If in fact it can be accidentally reversed how do I know which side is Right or Left.
Yes I know the tread pattern on the front tires are different but they're the same size and installed to allow for movement of the frame.
YES.Hard to see but it looks like they are installed on the wrong sides. The longer edge on the control arm should be towards front. Looks like the short edge is front.They should "swoop back".Pic from the top view would nail it
How close do I need to be for the alignment shop? In other words, do the trailing arm shims need to be exact or do they adjust those?
Hopefully you bagged and tagged when you removed them, BUT...
You are going to want a 4 wheel alignment by a shop that knows these cars anyway, when you get it back together. I would not worry about a short drive with the alignment out of specs, and when they get done it is one less thing to worry about. Even if you put the old shims back in, you now have a new tight suspension, and it was probably not that new when the last alignment was done.
It's nice to have an alignment that is good enough to drive around the block a few times to debug the car before taking it to the alignment shop.
To get the alignment good enough to not destroy your tires is easy:
Use a bubble level to set all 4 wheels straight up (zero camber).
Put a string between 2 jacks so the string runs along the side of the car at the height of the wheel hubs. Do the same with another string and 2 more jacks on the other side.
String should touch the tire at the front & back. In other words, make the tires point the way the string points. Since the C3 has slightly wider track in the rear you end up with a bit of toe-in (tires pointing inward) which is what you want.
Not a substitute for a real alignment, but now you can test drive it as much as you want without worrying about damaging tires.
Do the trailing arm shims have to be exact or will a 4 wheel alignment take care of lessening the bolt and repositioning the shims.
Anyone have a link to aid in me setting up a rough alignment in order to be able to dive it 15 miles to a shop as it's way off right now. I figure it's easier to do now before I place the top half back on.
Select TA shims so the tire touches the string front & back.That's how exact you need it.
When they do the alignment they may need to move a shim or two but that's included in a 4-wheel alignment. Be sure to use the slotted end of the shim. I once turned them around to where the TA bolt had to be removed to remove the shims.
Be sure to do the rough alignment I detailed above with all the weight on the car. If it sits high due to missing doors, engine etc, the alignment is useless as it changes drastically as the car settles lower.
Note the angle of your upper ball joints, as pictured. They're angled "down" (forward) at the front of the a-arm. They should angle back, towards the rear of the car...
