How to fix radiator leaking from overflow fitting?
Old Jul 2, 2015 | 10:03 PM
Scottd's Avatar
Scottd
Default How to fix radiator leaking from overflow fitting?
1972 Big Block radiator- leaking from the base of the metal barb that sticks out of the upper right corner. (The hose that goes to the overflow tank) Im thinking about wadding some cold steel around the fitting for a bubba repair. Im not interested in replacing, or even removing the radiator at this time.
Old Jul 2, 2015 | 10:09 PM
Sayfoo's Avatar
Sayfoo
If it's a copper/brass radiator, it needs to be soldered. You can do it on the car if you're handy, or, maybe $40 at a radiator shop?
Old Jul 2, 2015 | 11:08 PM
Scottd's Avatar
Scottd
Yeah, trying to do this without removing the radiator.
To How to fix radiator leaking from overflow fitting?
