EGR Valve Operation
http://www.aa1car.com/library/egr.htm
Which leads me to my 1994 Mustang GT 5.0 V8 and its EGR valve. The car has 30,000 miles on it and is bone stock except for a K&N cold air intake and BBK shorty headers (with an EGR valve pipe on one of the passenger side exhaust pipes to feed the EGR valve), Magnaflow X pipe with 4 high flow cats, and a magna flow cat back muffler system. Everything else is 100% stock...timing, engine temperature, etc.
The problem is that when fully warmed up, under mid to full throttle, between 3,000-6,000 RPM, the engine will ping, especially when the outside temp is over 80 degrees . I checked EGR operation (works perfectly), timing (stock Ford recommendation), wires, plugs..all good etc....everything is spot on. The Ford EGR valve will begin to open at any throttle position under load....closed at idle. Switching to 89 octane from 87 octane definitely helped the issue but did not eliminate it. Yesterday, I tried an experiment...I disconnected the vacuum port to the EGR valve eliminating its ability to open under any load (check engine light comes on since the electronic position sensor on the EGR valve detects no movement of the EGR valve). Guess what the outcome was? Pinging totally gone and the throttle response is so much better AND the engine temp actually decreased slightly from its normal operational temp. Preventing the EGR valve from diluting the incoming intake charge with 500 degree exhaust gas has LOWERED the combustion chamber temperatures eliminating the ping issue which has always been my theory for the last 30 years. The plan to eliminate the check engine light is to remove the pipe between the exhaust headers tube and the intake, capping both, reattaching the vacuum port to the EGR valve which will allow the valve to move (but no exhaust to enter the combustion chamber) which will satisfy the EGR position sensor monitor.
I am curious if anyone can explain why the supposed "cooling" effect of the EGR valve operation has been causing engine knock all these years in my 5.0 V8?
As you said, why do performance engines not have any of these controls? You can believe that C3 emissions controls are important to the environment if you want, but don't try to pretend it does not kill performance.
It's been about 2 months since I removed the EGR pipe from one of the header primaries and went home depot and bought two brass caps with the same threads as the intake EGR and the Headers EGR pipe thread to block the EGR gases from entering the intake @ 400-500 degrees. The car has never run better...crisper throttle response, runs noticeable cooler on the temp gauge, AND NO PINGING on a 90 degree day anywhere in the RPM range. The EGR valve continues to move under less vacuum and the electronic EGR sensor monitors the movement with no check engine light...$8 fix...just no hot gases entering the intake. Mileage has gone up AND 2 weeks ago the car passed the sniffer inspection with flying colors...CO at idle and 2,500 RPM was .02% (Limit 1.2%), HC at idle 13PPM, 19 PPM @ 2,500 RPM (limit 220 PPM)...so there you go..Better performance AND no meaningful effect on emssions..win/win
It requires vacuum to open.
From your article:
"When vacuum is applied to the EGR valve, it opens."
They even sell a screen you can install to keep the pintle clear of carbon to prevent the normally closed valve from being stuck open. A good accessory if you live in California, and have to endure these to pass smog.
