Shocks
Old Jul 7, 2015 | 07:11 AM
Bond007's Avatar
Bond007
Default Shocks
Hello Fellow Vetteheads,
Going to install some new shocks on my 76 Vette with gymkhana suspension any good ideas of what to put on?
Old Jul 7, 2015 | 11:49 AM
MelWff's Avatar
MelWff
Bilstein appears to be the most popular, Sport is stiffer than HD
Old Jul 7, 2015 | 12:07 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
KYBs could be an alternative to Bilsteins.
Old Jul 7, 2015 | 04:28 PM
mk's78's Avatar
mk's78
Default Just for your info..
My 78 came with an extra/spare set of KYB's that have less that 1500 miles on them.....
If interested in price etc....send me a message at dafb169@hotmail.com
mk's78
Mike
Old Jul 7, 2015 | 08:40 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Ultimately depends on your purposes, but IMHO a set of Bilsteins is one of the top 5 upgrades the majority of C3 owners should have on their to do list. My $.02
Old Jul 7, 2015 | 09:13 PM
MN80Vette's Avatar
MN80Vette
I replaced KYB shocks with Bilstein Sports on my gymkhana-equivalent suspension and love 'em.
Old Jul 7, 2015 | 10:15 PM
Bond007's Avatar
Bond007
Thank you all will check it out further and see what the prices are and go from there.
Old Jul 8, 2015 | 12:33 AM
MN80Vette's Avatar
MN80Vette
FYI, Bilsteins are $342 for a set of 4 Sports and $358 for a set of 4 HDs. Let me know if you can't find them for that price or less.
Old Jul 8, 2015 | 07:37 AM
jb78L-82's Avatar
jb78L-82
Bilstein as well...I have a 78 with originally the stock gymkhana suspension which had the 7 leaf steel spring and GM F-41 front coils. The stock steel rear spring was rated at 292lbs and the front coils were 300-350lbs? (can't remember off the top of my head). The car has 360 composite in the rear today (installed 1986) and 550 front springs, 1 inch lower than stock. I had KYB Gas A Justs in the rear for years...OK but not enough rebound control) and went to Bilstein HD's all around in the early 2000's....SO MUCH better! I currently have Bilstein Sports (30% stiffer than HD's) in the rear and HD in the front. I also have competition adjustable struts with Heim joints in the rear, Poly sway bar bushings front and rear, poly upper and lower control arm bushings, Front spreader bar, Custom rebuilt/blueprinted GTR1999 OEM steering box, etc. The ride, steering, and handling is SO much Better than the factory suspension ever was even new...much much more compliant than my 10 C6Z06. Stiffen the chassis, eliminate unwanted suspension flex, and a composite rear spring and you can go MUCH higher on spring rates than stock with an improvement in ride quality...modern materials are amazing.
Old Jul 8, 2015 | 08:03 AM
chase@ridetech's Avatar
0chase@ridetech
Former Vendor
Check out our Ridetech HQ Shocks.
They are monotube construction have had a specific valve code designed for the Corvette Suspension. Best of all they have a 1,000,001 mile warranty!
Check them out here:
http://www.ridetech.com/store/muscle...ures_hash=V366
Old Jul 8, 2015 | 01:19 PM
hugie82's Avatar
hugie82
I'm very happy with Koni Adjustable shocks. Only a few bucks more than Bilsteins but are more difficult to change adjustment than the much more expensive dial adjustable shocks .
Old Jul 9, 2015 | 12:37 AM
TheSkunkWorks
Sound like the Koni Special D's I have, but good shocks. Hope someday to step on up to full blown Koni double-adjustables, having been exposed to multi-adjustables enough to get spoiled.
Old Jul 12, 2015 | 09:52 PM
hotrodnick's Avatar
hotrodnick
If you get aggressive Bilstiens would be better but more expensive. My budget was only good for KYB Gas Adjust. They work for me made big change from 35 year old originals.
Old Jul 13, 2015 | 12:38 AM
l88rocket's Avatar
l88rocket
I put Ridetech on everything I build and own, its the best shock on the market, excellent customer service.
Old Jul 13, 2015 | 01:16 AM
havesometo's Avatar
havesometo
Old Jul 13, 2015 | 01:12 PM
TheSkunkWorks
Not questioning the quality of their wares, but each is entitled to their own subjective opinion. At the top end of the "shock" market are some pretty heavy hitters.
Old Jul 13, 2015 | 05:23 PM
7T1vette's Avatar
7T1vette
RideTech may be OK...but it's not at the top of MY list.
Bilsteins are top-notch and last MANY years without performance loss. For what you want, I'd suggest Sports.
To Shocks
