rear leaf spring
Old Jul 7, 2015 | 09:25 AM
upnorth's Avatar
upnorth
Default rear leaf spring
I replaced mine around 20 years ago and it need a new one now .if I remember I went with one that was 300 lb and 7 leaf . what I don't remember is if it was the flatter one or the curved one . I don't want the carbon fiber . so what would do you thing would be right for a 1976?
Old Jul 7, 2015 | 10:25 AM
dar322's Avatar
dar322
St. Jude Donor '12-'13
I think the 2.5" (fatter one) is for the 9 leaf. get under the car and verify your width before you order.
Old Jul 7, 2015 | 10:51 AM
upnorth's Avatar
upnorth
I will check but in pretty sure its 2 1/4 . its more the contour im looking to find out .
Old Jul 7, 2015 | 11:06 AM
sstopczy's Avatar
sstopczy
The spring should be curved, that's what gives it the spring properties. If it is flat it is no good.
Old Jul 7, 2015 | 11:26 AM
upnorth's Avatar
upnorth
the replacements all are curved to some degree . but in the steel there a original which has the big curve and is 192 lb and then theres the flatter one that's 300 lb . I don't remember but I think the flatter one is the one I went with 20 years ago . if its replaced at what height should the car sit .
Old Jul 7, 2015 | 11:59 AM
dar322's Avatar
dar322
count the leafs, its either 7 or 9 and the width can be 2.25" or 2.5". if the car sits to high, you can buy the next longer bolts. the 7 leaf may be a harsher ride due to the arch radius and may also be considered the gymkana.
Old Jul 7, 2015 | 01:40 PM
upnorth's Avatar
upnorth
just checked it its 7 layers and has 6 inch bolts . when sitting there the spring lays flat . but I measured the height of the car . suppose to 48 inch . I came up with 49 inches to top . so if the spring is bad like the mechanic says shouldn't the car be sitting lower .
Old Jul 7, 2015 | 02:14 PM
MelWff's Avatar
MelWff
has that mechanic worked on a lot of corvettes?
can you post a picture?
how are the half shafts in relation to the ground, parallel to the ground, higher in the center than at the wheels, or higher at the wheels than at the center?
Old Jul 9, 2015 | 09:37 AM
upnorth's Avatar
upnorth
he has two ( has 75 he pretty much building from the ground up) and his dad has one and he seems to know quite a bit about them . he also has all the assembly books for them . when looking at the axles they are higher in the middle but not much.
Old Jul 9, 2015 | 10:51 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
The 7-leaf is for the optional Gymkhana suspension and the 9-leaf is the standard spring.
Old Jul 9, 2015 | 12:07 PM
MelWff's Avatar
MelWff
according to the document below the height is 48.6" so 49 is fine. If you scroll through the document you will find the frame height measurements. I'm not convinced from what you have stated in this thread that you need a new spring.
https://www.gmheritagecenter.com/doc...t-Corvette.pdf
Old Jul 9, 2015 | 02:37 PM
bashcraft's Avatar
bashcraft
Did he happen to say why the spring is bad?
Old Jul 9, 2015 | 05:11 PM
upnorth's Avatar
upnorth
said that there should be a bend in it when the car is sitting there . the spring looks straight no bend at all in it .
Old Jul 9, 2015 | 05:19 PM
upnorth's Avatar
upnorth
did learn a thing from this .I been trying to find replacement seats for mine and everything I find is vinyl or leather . your document shows that 1976 to 1982 they made 905 with a fabric seat and doors . I have one of the 905 .
Old Jul 9, 2015 | 06:46 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
More important than whether your spring is arched or flat when loaded is your rear ride height, with front "Z" and rear "D" being the most preferable references since non-standard tires won't change those measurement. Factory tolerance for either was +0.25". And, unless the diff cover has been changed to a 78-79 one the spring width should be 2.25" thru '77.
Old Jul 10, 2015 | 10:00 AM
upnorth's Avatar
upnorth
just real quick did j and k .
J im about 1/2 inch higher and on K I am 1 1/4 lower . so back end is squatting .
Old Jul 10, 2015 | 10:42 AM
Dodosmike's Avatar
Dodosmike
Regardless if the spring is "flat" are the half shafts level? or higher at one end compared to the other?
If your running a stock(ish) spring, 6" bolts and the outer end of the half shafts are higher than the middle, IMO your spring is in need of replacement. This assumes all other item are good, like #3 and #4 frame mounts are solid and the fiberglass around the #4 body mount isn't cracked and broken.
One option would be to tighten up the nut on the 6" bolt, but if the spring is "done" that's a band-aid fix.
Why don't you want to look at fiberglass springs? Just want to maintain originality?
dodosmike
Old Jul 13, 2015 | 12:30 PM
MelWff's Avatar
MelWff
Default Spring
dodosmike
In post #9 above the OP states the inner is higher
To rear leaf spring
