bad carb luck!
Old Jul 8, 2015 | 09:14 AM
Molly Issa's Avatar
Molly Issa
Default bad carb luck!
have a 79' Vette, she failed smog. I was told the carb is too lean and that is why my nox are up. well I had this car 3 years. This is my third Quadrajet. Current carb is a nos Quadrajet rebuild by Holley or called Holley II. Thing runs fine, better than the old carbs. I am sick of dumping money on parts that do not last. I wanna stay stock but who sells decent rebuilds? I do not wanna go Edelbrock and change all that stuff out. I just want a stock carb that works and not for 500.00. Am I asking too much? This carb thing is getting really old! I welcome any suggestions. Thanks, Steve
Old Jul 8, 2015 | 09:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not sure what you're asking. You say you failed emissions because of a lean mixture. Can you not enrich the mixture and try testing again?
Old Jul 8, 2015 | 10:11 AM
commander_47's Avatar
commander_47
Hey, allow me to be the first to recommend that if you want to stick with the Q junk, then email LARS.
Old Jul 8, 2015 | 10:30 AM
jnealg's Avatar
jnealg
^^^ <SNORT> funny but true.
Old Jul 8, 2015 | 10:44 AM
clwi's Avatar
clwi
Send this guy an email, he rebuilt my Quadrajet, runs like clockwork!
He has been doing this for 30 years and have customers in US that shipped the carb for rebuild, lives in Sweden.
kentsqjet@hotmail.com
Old Jul 8, 2015 | 11:21 AM
MelWff's Avatar
MelWff
1. Your state doesn't have emissions exemptions for cars older than 25 years?
2. What test is performed, idle emissions only or at various engine speeds? If idle speed only adjust the idle mixture screws.
3. Too lean a mixture can be also caused by a vacuum leak in a hose, may have nothing to do with the carburetor.
4. A bad EGR valve will also cause high NOX readings.
Old Jul 8, 2015 | 02:29 PM
mikem350's Avatar
mikem350
Ditto vac leak...take off egr and clean ports, make sure the pintel is closing...or maybe unplug and cap vac hose to egr
Ask a shop to tweek carb, timing etc with 3 gas analyzer!
Old Jul 8, 2015 | 02:37 PM
rcread's Avatar
rcread
You don't want a Q-Jet that's been touched by Holley. They are butchers when it comes to Quadrajets. I think they intentionally botch them so people will switch to Holley carbs.
Old Jul 8, 2015 | 02:49 PM
lars's Avatar
lars
The Holley reman Q-Jets are exceptionally bad - I've never seen Q-Jets hacked worse than those built by Holley. The lean problem is typical of the Holley builds - they set the APT far too low, and often use jet/rod combinations that produce extreme lean conditions that will cause you to fail emissions. You're best off finding a used, original, unmolested carb and having it built correctly. Good, used rebuildable Q-Jets are available on eBay for under $100.
Old Jul 8, 2015 | 03:18 PM
dochorsepower's Avatar
dochorsepower
Yes, go see Lars. A good Q-jet is a marvelous thing. The key word being good.
Old Jul 8, 2015 | 03:47 PM
clwi's Avatar
clwi
As i said in a previous post, Kent in Sweden is a Q-jet wizard!
Old Jul 8, 2015 | 05:02 PM
Shark Racer's Avatar
Shark Racer
Has EGR been tested and known to work? The only time I've ever had issue w/ NOX was when my EGR was in-op or I was running too much timing advance.
Old Jul 9, 2015 | 08:46 AM
Molly Issa's Avatar
Molly Issa
I have still have the carb the car came with. It did have a leak down issue from the plugs in addition to whatever else was going on in there, throttle fluctuating, etc.. would this be worth rebuilding. Would not be surprised if this is the original carb for the car. Would you be willing to take this carb and rebuild it for me? If so can I email you and work something out? I am in California. Thank you for your time, Steve
Old Jul 9, 2015 | 08:55 AM
Molly Issa's Avatar
Molly Issa
So for the other members giving me input, this is the deal, the egr is new. I suspect the cat is bad due to running too lean too long, I am getting a deal one one today. Once I fix this I am sure she will pass but the carb nightmare continues. As far as smog goes, it failed the 25 mph test with high hc and nox. Mechanic stated lean carb is the problem. Since it is an old stock rebuild by Holley I don't think it is worth messing with at this point. I wanna get a good one, slap it in and be happy. Then I will take the Holley and have that one built properly and kept as a spare in my closet. California, 1975 and on you have to smog forever. They even make the test harder with this pressure test thing with the gas tank now. What a load of bull. So that is where I am at.
Old Jul 9, 2015 | 11:27 AM
Shark Racer
Yeah, high HC coupled with high NOx sounds like lean misfires to me.
Wanna drive it up to the San Jose area?
Old Jul 9, 2015 | 01:57 PM
dugsgms74's Avatar
dugsgms74
If you can post a pic of the smog report that might help.
Old Jul 10, 2015 | 09:20 AM
Molly Issa's Avatar
Molly Issa
had a new cat installed. the old one was clogged plus it had a lot of what looked like white sand in it, like from a charcoal bbq. car passed smog. the bad is I have a leak with the evaporate system that now caused it fail again and I screwed up and set the timing a little high. So sick of this. I hope to persuade Lars to take one of my carbs. I cannot afford to do the edelbrock transformation. ah sooooooo much fun. I will try to reply to posts asap but I cannot log in via facebook on my phone. I have to use my work computer.
Old Jul 10, 2015 | 12:12 PM
Shark Racer
Lars won't be able to fix your evap problem, unfortunately. Hopefully all you have to do is replace the lines in the engine bay.
Old Jul 10, 2015 | 07:05 PM
dugsgms74's Avatar
dugsgms74
Seems like you failed the evap system pressure test. This test puts a slight amount of pressure in the fuel tank and measures the leak down rate. Parts included in this test is the fuel tank, fuel cap and all hoses up to the charcoal canister. Like Shark said, hopefully the problem can be repaired by replacing the easy to access vapor lines/hoses under the hood.
To bad carb luck!
