adjusting linkage for 4th gear?
Old Jul 8, 2015 | 02:27 PM
71vet's Avatar
71vet
Default adjusting linkage for 4th gear?
Whenever I shift into 4th gear, it feels to me like the linkage is not pushing all the way into gear. It seems like the shifter should move slightly more backwards, and now at times there is a grinding when going into 4th. It does not pop out of gear. Is it hard and where would I be able to adjust the linkage for 4th gear? All other gears work fine.
thanks
Old Jul 8, 2015 | 02:34 PM
jnb5101's Avatar
jnb5101
The shifter itself may be working loose. You will have to get under the car to check the two bolts.
Old Jul 8, 2015 | 02:53 PM
MelWff's Avatar
MelWff
also check the 3/4 shift rod adjustment nuts, they maybe loose.
To adjusting linkage for 4th gear?
