Success!
Old Jun 28, 2015 | 04:42 PM
SwampeastMike's Avatar
SwampeastMike
Default Success!
Yes, I'm a Corvette newbee cranking my own chain but I won't apologize.
After LOTs of hours and 100s of $$ I FINALLY have a fully functioning electrical/lighting system in a low (about 50k) mileage '79 that came from the factory with every convenience. With the exception of all of the horns (alarm-dead; low note-shorted; high note weak/intermittent) and a slightly wonky upper horn contact (one plastic rivet loose) everything works exactly as designed even if the right-hand headlight is a bit reluctant to rise and I can only get 1/2 operation of the headlights (up or down but not both) with the engine off.
I can FINALLY take a drive of about 200 miles total to visit my uncle who bought numerous C3s new when he was in his 20s and 30s. He said of his '69 427ci "I had to sell it before I killed myself".
Old Jun 28, 2015 | 04:54 PM
oldgto's Avatar
oldgto
I feel his pain!
But dammit.... I LOVE this POS so much!
Old Jun 28, 2015 | 06:46 PM
SwampeastMike
Originally Posted by oldgto
I feel his pain!
His comments about his new '69 (I'm not sure of the exact variant of the 427) were "Weekly or even daily adjustments of the rocker arms/valves" and "It would lift at very high speed and you'd loose traction. I almost had it flying once and scared myself silly because I still wanted to go faster."
Old Jun 29, 2015 | 06:48 AM
7T1vette's Avatar
7T1vette
Your horn and buzzer problems are likely due to a worn-out or faulty horn relay. That relay also serves as the buzzer.
Another possibility is that you have swapped out the original steering 'ragjoint' for a new one. The original had wire mesh imbedded in it so that electrical ground could travel through the steering column. The new ragjoints are not made with that grounding mesh.
Make up a temporary jumper wire (12 ga.) to bypass that ragjoint, connecting upper column with lower section. Then try the horn. If that works, install a short jumper wire with loop lugs to bolts on each half of the ragjoint.
Old Jun 29, 2015 | 11:27 AM
SwampeastMike
I removed and bench tested all of the horns so am confident the low note is internally shorted, the high note weak and intermittent and the alarm dead. Yes, a wonky horn relay was also part of the problem and has been replaced. I've verified that I get horn button on the wheel provides ground to the relay when pressed.
Old Jun 29, 2015 | 01:06 PM
7T1vette's Avatar
7T1vette
If you did an electrical continuity test on the horns (ohmmeter), they would show very low ohms reading. The horn is basically a coil, so resistance is low.
I'm still of the opinion that you have an electrical problem. Time will tell...
Old Jun 29, 2015 | 02:21 PM
SwampeastMike
I tested them with a fully charged battery and fused positive lead. One blew a 20A fuse, one was utterly dead, one week sounding and would cut out but come back with a little hit. On the meter they read about 1 1/2 ohms, infinite and 2 ohms respectively.
Old Jul 8, 2015 | 11:11 AM
joncro55's Avatar
joncro55
Navigator
When you are talking about this "wire mesh" and electrical ground - are you talking something like brass? or stainless steel? Any ideas on that? I am assuming this is woven wire mesh - something along the lines of what can be seen here: http://www.bwire.com
Old Jul 8, 2015 | 03:31 PM
dochorsepower's Avatar
dochorsepower
"a slightly wonky upper horn contact (one plastic rivet loose)"
Only one? Horn contacts are a common replacement issue. Buy replacement from GM, not aftermarket, many of those don't fit right.
To Success!
