1977 C3 HELP WITH CAM 383 Stroker
Old Jul 8, 2015 | 11:12 PM
zizza77c3's Avatar
zizza77c3
1st Gear
Default 1977 C3 HELP WITH CAM 383 Stroker
Hey everyone how are all of ya. I am building my first c3 corvette I need some help with cam selection for a 383 I would like 450 HP looking for sugestions on cams that will help me get their without taking all my vacuum away for the headlights and brakes this is for the street not track also looking at AFR Heads or the 202 Dart heads 750 double pumper carb msd ignition with 6 al box still looking at intakes any help their would be great single or dual plan trying to keep the stock hood but seems impossible Thanks For any help would be great.
Old Jul 8, 2015 | 11:43 PM
toobroketoretire's Avatar
toobroketoretire
First of all "double pumper" carburetors are made specifically for drag and track racing where an engine speed of 4000+ rpm can be maintained. For street use ONLY use vacuum secondary or AVS carburetors to prevent low speed bogging.
Old Jul 9, 2015 | 07:58 AM
rdroket's Avatar
rdroket
toobroketoretire:
I do not agree with your statement. I have 750 double pumpers on two cars and have no problem with bogging during street use.
Old Jul 9, 2015 | 09:01 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
For an intake, I'm running a Team G p/n 7530. Carb height is about the same as stock intake. I have a 1-3/4" drop base and a 4" x 14" filter under my stock hood. I also have a Holley Street HP 650 DP. I would suggest a 750 for a 383. I would also recommend a hydraulic roller cam. My car is street use only but I like a bit more power than stock. Unless you have a lead foot, there is nothing wrong with using a mech'l secondary carb with dual accelerator pumps on the street.
Old Jul 9, 2015 | 09:25 AM
StraubTech's Avatar
StraubTech
AFR 195
Hyd Roller Cam in the 220 .050"Duration
Airgap intake
850HO Carb
No sweat making 450+ HP and having excellent street manners.
Old Jul 9, 2015 | 01:01 PM
BKbroiler's Avatar
BKbroiler
The key to hood clearance is a drop base air cleaner. On my 77, with the stock hood, I have Edel. RPM air gap maifold and a 3/4 inch adapter under the carb. The air cleaner is 1.5 inch drop base with 3 inch element. Its tight, but it fits.
Old Jul 9, 2015 | 11:01 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Originally Posted by StraubTech
AFR 195
Airgap intake
850HO Carb
Listen to this man ^^^^ and ditto on the double pumper, properly tuned they are tops for this type of build unless you step up to EFI.
Old Jul 10, 2015 | 07:57 AM
cooper9811's Avatar
cooper9811
AFR 195
Airgap intake
850HO Carb
Right on the money - had a 383 with AFR 195s and similar cam - I still have the short block - it's a good combination.
And like others, I completely agree a DP, properly set up, will work just fine.
Old Jul 11, 2015 | 02:13 AM
bluedawg's Avatar
bluedawg
Afr 195/ 64, 10.2 to compression ratio and either comp xe288hr or a custom cash aft. The first will surpass 450 horse.
Old Jul 11, 2015 | 06:23 PM
keithl1967's Avatar
keithl1967
I'm running a Comp Cams Hydarualic roller--XR282HR--in my 406 in my camaro...10.03:1 static. Sounds nice, idles well at 800 rom, and holds decent vacuum (11", if I remember correctly)...
750 Holley DP here...tuned properly a DP is perfectly fine for the street...
Old Jul 12, 2015 | 08:28 PM
toobroketoretire
Originally Posted by rdroket
toobroketoretire:
No factory engine has ever come with a mechanical secondary double pumper carburetor for the reason I stated. And that includes the powerful L-88 and 426" Hemi.
To 1977 C3 HELP WITH CAM 383 Stroker
