Steeroids: My Turn Today!!
Old Aug 19, 2002 | 11:57 AM
73454's Avatar
73454
Default Steeroids: My Turn Today!!
I finally got me a day off to do this little project.
I've got a squeak in the rear-end to check out also.
I can't wait to get this done!
Have a nice day.
Old Aug 19, 2002 | 06:07 PM
mrvette's Avatar
mrvette
Default Re: Steeroids: My Turn Today!! (73454)
Squeek in rear is usually sway bar bushings...mine are urethane, and I have to keep greasing them on account of all the rain we been having here in N Florida...
GENE
Old Aug 20, 2002 | 01:26 AM
73454's Avatar
73454
Default Re: Steeroids: My Turn Today!! (mrvette)
Thanks Gene, unfortunately this is a rotational type squeak, it's most of the time, straight line, and not very loud. I will be re-checking the brakes and u-joints first. I already removed the emergency brakes.
So far the Steeroids kit installation is going fine but they sent an incorrect high-pressure hose so it's on hold until that is resolved.
Old Aug 20, 2002 | 05:08 PM
groovyjay's Avatar
groovyjay
Keep us updated how it turs out! :cheers:
Old Aug 20, 2002 | 07:28 PM
Jay M's Avatar
Jay M
They REALLY need to do some sort of quality control! YOu may have seen my post about their quality problems.
But the kit is awesome! I just returned from a long drive up the California coast to the Monterey Historics. The car is an incredible joy to drive now. Adding the new Momo steering wheel made a huge difference as well.
All I need are modern seats and A/C and I'll no longer envy C5s or M-roadsters.
~Jay
Old Aug 23, 2002 | 01:52 AM
WADE1965's Avatar
WADE1965
Default Re: Steeroids: My Turn Today!! (Jay M)
Hi.They tell me this is a saganaw rack.Could you tell me the part numbers off of the rack so I could see which one they are using for this kit? You help would be much appreciated.Thanks :cheers:
Old Aug 23, 2002 | 05:50 AM
73454's Avatar
73454
Default Re: Steeroids: My Turn Today!! (WADE1965)
I'm going to finish up the installation Friday afternoon and I will get the number for you then and post it Friday night.
Unless someone beats me to it :jester
Old Aug 24, 2002 | 11:41 PM
73454's Avatar
73454
Wade: The only visible numbers I see are arranged like this:
"8 3 062" and then there is a very large 'B' on the steering shaft boss.
I hope this helps, I don't recall seeing any other numbers before installing it.
I understand that these racks are the same used in many mid-eighties and early nineties GM vehicles.
By the way - The steering is vastly improved over the stock set up :cool:
Old Aug 25, 2002 | 02:45 PM
mrvette's Avatar
mrvette
Wade if you want to doyour own install, the rack and hoses best to use come from a '92 Grand am.....linkage from lumina's...lumini??? luminausses???
at any rate, get luminated for linkage....
GENE
Old Aug 26, 2002 | 11:24 AM
WADE1965's Avatar
WADE1965
Thanks for your help! :cheers:
Old Aug 26, 2002 | 11:42 AM
WADE1965's Avatar
WADE1965
mrvette
Did you fab your own brackets for the rack? And do you mean that the tie rods are from a lumina or the steering shaft and u-joint or both. How is the lock to lock compared to the original box. Thanks
To Steeroids: My Turn Today!!
