How tight is Front Shock Nut??
Old Aug 19, 2002 | 01:14 PM
VettePower's Avatar
VettePower
Default How tight is Front Shock Nut??
I put on new front shocks and was wondering how tight do you make the top mount nut. Could not see in the directions how tight to make it. :confused:
Old Aug 19, 2002 | 01:52 PM
72GACRZR's Avatar
72GACRZR
Default Re: How tight is Front Shock Nut?? (VettePower)
:confused: I don't know for sure, but I was once told to tighten till rubber bushing was flush with edge of washer. I then put old nut on top of new to lock it.
Old Aug 19, 2002 | 01:54 PM
gmcclurg's Avatar
gmcclurg
I usually tighten them enough so that the rubber bushings are in full contact with the washers and are just starting to expand slightly. You don't want to overtighten them and have teh rubber bulging out.
Old Aug 19, 2002 | 02:04 PM
JMV's Avatar
JMV
Default Re: How tight is Front Shock Nut?? (72GACRZR)
What kind of shocks did you get?
Old Aug 19, 2002 | 02:20 PM
VettePower's Avatar
VettePower
Default Re: How tight is Front Shock Nut?? (JMV)
[ : What kind of shocks did you get?[/QUOTE]
I got thr Delco Reactek. I need the smooth ride that these shocks offer I am getting tired of getting banged up with the old performance shocks that were on there before. :yesnod:
Old Aug 19, 2002 | 07:15 PM
JMV's Avatar
JMV
Will probably replace mine next spring :cheers:
To How tight is Front Shock Nut??
