Coolant sensor
Old Jul 12, 2015 | 11:19 PM
dallas121469's Avatar
dallas121469
Default Coolant sensor
Okay. I need to get the plug out of the coolant sensor location on a transplanted SBC. In my previous car it was mounted on the rear of passenger cylinder head. I want it in the stock location (front of driver cylinder head) due to wiring. My 1/4 sockets are too small and my 3/8 socket is too big to fit into the square in the screw in plug. Other than grinding down a 3/8 to fit anyone have any other suggestions. Is there a tool? Thanks.
Old Jul 13, 2015 | 10:35 AM
toobroketoretire's Avatar
toobroketoretire
How big is the square? If its 3/8" use the end of a 3/8" extension. If its 5/16" use a piece of 5/16" key stock and an 8-point socket.
Old Jul 13, 2015 | 12:25 PM
gungatim's Avatar
gungatim
there is a tool, basically a small 3/8 drive extention w/o the detent ball. When I worked at a quick lube, those plugs (were also used in rear diff's.) we just used a ratchet and 1" extention. you may have to tap it in if the ball is tight or the plug is rusty.
Old Jul 18, 2015 | 12:21 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
I had to take a 3/8 extension and sacrificed it by grinding it on my bench grinder a little at a time until it fit. .
Old Jul 18, 2015 | 10:51 AM
mikem350's Avatar
mikem350
Make sure to square off the tip, and hammer it all the way in flush. These can be a bitch to get out...
To Coolant sensor
