Brake issues
Background:
I bought my 76 in April 2014. It had spongy brakes but it stopped well enough, so I drove it off and on till fall (not the best idea, I know that now). One night I noticed the pedal went almost to the floor before the car stopped,
so I parked it for the fall/winter. I finally dug into the brakes a few months ago and found the left rear caliper was leaking, so I replaced it and put new pads on the car all around. The others appeared fine. Nice and dry. I bled the car as best I could, but the pedal never felt very firm. Still pretty spongy. I thought I simply had done an inadequate job bleeding the system, so I finally decided to pay a shop to do it, just to rule out my own incompetence.The brakes still feel spongy. They're a little better than before, but the pedal goes halfway to the floor before the brakes even Start to grab. Once I get stopped, there is only about 1/4" to 1/2" of travel left before it's at the firewall. Now maybe maybe I'm expecting too much, but I think I should have a lot more pedal than that.
I've read that there's a rod in the Booster that actuates the piston in the MC... perhaps that is somehow improperly adjusted? Or maybe something to do with the vacuum fitting on the booster?
I've read several times on this forum, and others, that when everything is right the pedal is "rock hard" and the brakes can "throw you through the windshield." Maybe that's an exaggeration, but still. I just want good brakes so I can move on to other things. I can't well do much with a car that won't stop reliably. What am I missing here?
But... I'd try all easy options first!
Thanks for the help guys. While it's hotter than Satan's buttcheeks here and my car doesnt have A/C, I'd still rather be driving it than my DD. Got to get this brake problem figured out.
Any more responses? So far I have suggestions to re-bleed and to check the brake booster pushrod length. Anything else? I'd like to look over everything at once instead of doing it piecemeal.
Thanks.
Try bleeding the system again. You can also replace the bleeder screws with those that have a check ball in them (commonly known as "speed bleeders" available at your local auto parts store) They prevent air from being sucked back into the calipers.
Is/was your brake warning light on when you discovered the leaking caliper? Was the MC fluid level low on either reservoir?
