1974 Ammeter to Voltmeter Conversion
Strangely, I discovered last week that my ammeter never moves from "0", slightly on the (+) side. It has been that way for years. I thought it was normal but I guess not. Someone at a recent show made that comment. Live and learn! I do not have other electrical problems. But I do not wish to introduce any. I do have a new ammeter on order but can return that for a voltmeter. Or should I just drive free of electrical problems.
Joe
I converted my 75 to a volt meter and just borrowed power from the gauges power wire.
The wire that "feeds" your amp gauge connects to a 10-gauge wire right behind your distributor. Unwrap the harness and you'll find a very fine wire that has come undone from the larger 10-gauge wire (that I assume comes from the horn relay. My amp gauge didn't work either and then one day when I was unwrapping the harness behind my distributor I ran across a small single-strand wire that appeared to have been connected to a large 10-gauge wire (hmm). I re-connected it and VIOLA my amp gauge started working and has worked ever since. Try that before swapping gauges.
http://www.madelectrical.com/
Be prepared to spend some time talking to him (45min is a short conversation) He'll tell you everything you need to know about your electrical system,and the way s to improve it.
Believe me this guy knows his old muscle electrical
Good to see that you are still on the Forum! You know, 15 years is a long time.
Check this thread:
https://www.corvetteforum.com/forums...amp-gauge.html
There is instructions on how to test your original ammeter using a used battery. But hold the battery connected for only a second to see if the needle moves.
Personally, I would leave the ammeter in place and get a digital voltmeter and plug it into the cigarette lighter.
Despite what others say, the only way to really know what your electricals are doing is to have both and ammeter and a voltmeter. I added a voltmeter on my 73 for decades as an add on meter(digitals weren't invented yet).
example:
If your voltmeter is high and your ammeter is showing a charge, your regulator is probably shot.
If your voltmeter is normal and your ammeter is high, your battery is probably shot.
If your voltmeter is low and your ammeter shows discharge, your alternator may be shot or you have a bad short somewhere.
If your voltmeter is normal and your ammeter shows discharge, you probably have a short somewhere or just have your $5000 stereo turned on and too loud.
The corvette ammeter is really a voltmeter that reads the voltage drop across a known resistance wire that is in parallel with the charging wire. You might have an open in this resistance wire so you will be charging normally but your gauge doesn't work. It's probably a simple fix without buying another ammeter.
Steve L
73 coupe since new
Capital Corvette Club
Check this thread:
example:
Steve L
73 coupe since new
At this point I am left with the two stub (black ****) ends of the fusible link. And I don't know what their purpose is. But their wires are isolated now so no shorts will occur. I have given up for today as tomorrow I have to attend a funeral for a long-time family and dear friend who suffered from dementia for many years. It is so sad to see the mind go and the body persist. But he has now found peace.
I will consider the voltmeter option again and perhaps return the new ammeter for an exchange.
If it shows those discharges, the meter and wiring are probably fine. If the meter moves, but not nearly the correct amount, your meter is probably fine...but it is not wired into the harness correctly.
If there is NO movement during this test, your ammeter has failed.
P.S. There is very little current that is passed THRU the ammeter. It really measures the small voltage drop across a lenth of main power wiring in the harness. The scaling on the dial just allows you to read AMPS.
The car still runs extremely well. No electrical problems. I am not going to fool about with ammeter wiring and spoil my summer.
easy fix
https://www.corvetteforum.com/forums...locations.html
