gas
Old Jul 18, 2015 | 12:58 PM
upnorth's Avatar
upnorth
Default gas
at what point or how do you know when 91 octane gas isn't enough
Old Jul 18, 2015 | 01:11 PM
Revi's Avatar
Revi
When you can hear or feel detonation.
Old Jul 18, 2015 | 01:24 PM
74modified's Avatar
74modified
And - when you shut it off, it wants to keep running
Old Jul 18, 2015 | 01:35 PM
upnorth's Avatar
upnorth
mine does that sometimes . so what I do is leave it in gear when I turn it off and usually it will stop . when I had the idle a little higher it was a problem .
Old Jul 18, 2015 | 01:48 PM
74modified's Avatar
74modified
In regular pump gas, the higher the octane, the less "explosive" it is. So, with higher compression it could act like diesel and explode just from compression and no spark. Same for the pinging and detonation, it explodes before the spark plug ignites it or too quickly. You may need to just back off of your timing.
Old Jul 18, 2015 | 02:48 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Good answers above. You need to fix the problem as engine damage could result. First thing I'd do is check the timing.
Old Jul 18, 2015 | 02:50 PM
toobroketoretire's Avatar
toobroketoretire
When you hear your engine "rattling" under a heavy load.
Old Jul 18, 2015 | 03:06 PM
upnorth's Avatar
upnorth
haven't heard that sound but I don't have any hills here to pull . when I lived in tn. 20 years ago and had my 308 gear and 750 double pumper I use to run blue fuel ( not all the time was a little pricey even back then ) which was either 105 or 108 octane cant remember which. that's when I came close to pegging the speedo hit 152 according to it and it still had more .
Old Jul 18, 2015 | 03:22 PM
74modified's Avatar
74modified
Octane ratings are not indicators of the energy or power content of gasoline. Octane rating is only a measure of the fuel's tendency to burn in a controlled manner, rather than exploding in an uncontrolled manner. If you have an engine with high compression, the higher octane will allow you to tune it to make more power. It is a waste of money to use higher octane if your engine doesn't need it - the fuel doesn't have more power- with the exception of some oxygenated race only fuels.
Old Jul 18, 2015 | 03:28 PM
upnorth's Avatar
upnorth
im running 11 to 1 speed pro 7070p pistons and average 220 psi per cylinder if I did the my compression test right .
Old Jul 18, 2015 | 06:36 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Read the spark plugs, paying particular attention to the white porcelain insulators (internal) for any fusing of tiny black or shinny specs or tiny spheres. Next step up the detonation scale is damaged insulators or even electrodes, then holing a piston and associated carnage. Best to read them immediately upon shutting down at the big end from a WOT 1/4 mile pass or a full dyno pull, but you don't want to do either if already seeing/hearing any signs beforehand. Plenty else to learn from reading them... HTH
Old Jul 19, 2015 | 12:31 PM
REELAV8R's Avatar
REELAV8R
You running 64 cc heads with .025 in the hole and a .021 or less head gasket? What cam do you have? Figure your DCR and CR accurately for an idea of what it needs. Aluminum or cast iron heads?
Old Jul 19, 2015 | 12:47 PM
upnorth's Avatar
upnorth
world sportsman 202/160 cast heads with angle plugs crane roller rockers .the one thing I cant find a record on is my cam . im pretty sure ( 25 years ago back then I had bought a 350 hp rebuild kit then after that I went to the 11 to 1 and one size up cam ) its a 488/ 50 something .for the heck of it I just checked gas mileage . running it pretty hard got 8
To gas
