4-speed shifter
Old Jul 20, 2015 | 12:38 PM
Wig's Avatar
Wig
Default 4-speed shifter
I purchased a shifter rebuild kit and it has the thick and thin shifter reverse interlocks. The installation diagrams show the order that the plates should go in, but I can't see how the shifter can get pass the interlock to go to reverse. The only way I could get it to work was to put the interlock at the end where it doesn't come into play. Can anyone tell me how it would work if installed per the instructions?
I have a 1970 corvette and it has the BW ST10 4-speed.
Old Jul 20, 2015 | 02:50 PM
MelWff's Avatar
MelWff
does the picture showing the sequence help?
http://www.corvettemagazine.com/tech...ifter-rebuild/
Old Jul 20, 2015 | 03:38 PM
Wig's Avatar
Wig
I did it that way , but could not get shifter tip to move over to reverse by the interlock.
Old Jul 20, 2015 | 04:48 PM
MelWff's Avatar
MelWff
do you mean when installed on the car? If so did you adjust the linkage using the metal tool inserted into the shifter? see link
https://www.corvetteforum.com/forums...uncie-m21.html
To 4-speed shifter
