American racing TT2 question
Old Jul 31, 2015 | 11:58 AM
clwi's Avatar
clwi
Default American racing TT2 question
I am about to replace my original rims to 17x8 TT2 on my `72 BB.
Think the boltcircle is 5x4,75 and backspace 4,00...am i right?
Also what is the original offset?.
What tires are you guys running if you have theese rims?
Car is stock and not lowered.
Old Jul 31, 2015 | 01:46 PM
JimLentz's Avatar
JimLentz
Are you sure the backspace is 4.00 and not 4.5? An offset of 0 with an 8 inch wheel equates to a 4.5 inch backspace. An offset of -12mm equates to a 4 inch backspace with an 8 inch wheel.
This was posted by someone else on the forum.
Old Jul 31, 2015 | 02:13 PM
clwi's Avatar
clwi
I asked this question about backspace earlier and got the answer 4,00 backspace...i am not sure!
Old Jul 31, 2015 | 02:21 PM
JimLentz's Avatar
JimLentz
17 x 8 wheels with a 4 inch back space are hard/expensive to find. I just bout some 17 x 8 wheels with a 4.5 inch backspace. If everything works I will leave things as is, otherwise I will have to get longer wheels studs and use a 1/2 inch wheel spacer. For my wheels I got some 235/55 R17 Cooper Zeon RS3-A tires. I considered going 255/50 R17, but wasn't sure if I would have rubbing problems. I think that would have been fine if I had gone with the 1/2 inch spacers. When you mount the wheels check for clearance of the wheels and tires.
Old Jul 31, 2015 | 02:42 PM
clwi's Avatar
clwi
AR TT2 17x8 is available with -11 offset, are theese suiteable to my 72 vette??
Old Jul 31, 2015 | 02:57 PM
JimLentz's Avatar
JimLentz
That should be VERY close to a 4 inch backspace. How much does a custom backspace add to the cost?
Old Jul 31, 2015 | 03:25 PM
clwi's Avatar
clwi
They are -11 or +8 offset and 4,07 backspace.
Custom is 100USD more/rim....
Need advice!
Old Jul 31, 2015 | 05:07 PM
MelWff's Avatar
MelWff
I just installed the 17x8 with 4.07" backspace offset -11 on my 69. If you use the American Racing website and input your year and car they give you the information you need.
http://www.americanracing.com/wheels...model=Corvette
Old Jul 31, 2015 | 05:20 PM
clwi's Avatar
clwi
Thanx MelWff, it is just what i tought, they will suite me well!
What tires do you use?
Old Jul 31, 2015 | 05:29 PM
flyeri's Avatar
flyeri
17x8 4.07" backspace is what you want. Forget talking about offset and backspace in the same sentence. It is simply a different term expressing the same thing. If you get much more than 4" backspace on a 17" wheel you may run into interference with the parking brake cable bracket. I have these wheels with plenty of clearance.
Old Jul 31, 2015 | 05:58 PM
clwi's Avatar
clwi
Thanx for your input, i am going for those rims!
Old Aug 1, 2015 | 09:37 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I'm using the TT2's as well on my '72.
I have been very happy with the Nitto NT555 tires.
Old Aug 1, 2015 | 09:41 AM
zwede's Avatar
zwede
Stock rims were 15x8 with a 4" BS. Since you're sticking to an 8" wide rim you need to get one as close to 4" BS as you can.
I'm using Nitto 555 tires in 255/50-17. They're good tires and reasonably priced.
Old Aug 1, 2015 | 09:45 AM
3JsVette's Avatar
3JsVette
The perfect size tire would be 255/50-17s because they are 27" tall the same as stock but.........there's always a but........there could be rubbing issues in the front. There are some C3s on this forum running that combination with no issues.
Do want to run the same size front and rear so you can rotate? If so that size might not work. If you're not concerned with rotation buy 2 and test fit. I think if there were rubbing issues it would be with the wheels turned. Take a look at a '78 Pace Car and note where the fenders were trimmed from the factory on the leading edge and rear corner of the front wheel well. As mentioned above the 235/55-17s should work with no issues.
Old Aug 1, 2015 | 10:44 AM
clwi's Avatar
clwi
Same size back and front?
No rubbing issues?
Old Aug 1, 2015 | 11:35 AM
zwede's Avatar
zwede
No rubbing issues?
Same size front and rear. I clearanced the fender lips and there's an occasional light rub with the wheels turned all the way (hitting one of the steering box bolts). You can use a 245/50-17 up front and it should clear.
Old Aug 3, 2015 | 02:46 PM
MelWff's Avatar
MelWff
Default tire size
No rubbing issues?
Since I couldn't take a chance with rubbing I went with 255/45x17. They are approximately 1 inch less in diameter, 26". I went with the BF Goodrich g-force comp 2, a summer only tire with a W speed rating. Much better than the old 15" TA's.
To American racing TT2 question
Old Aug 3, 2015 | 09:24 PM
flyeri's Avatar
flyeri
255/50 rear and 245/45 front
Old Aug 4, 2015 | 06:07 PM
clwi's Avatar
clwi
OK..Now i have 215/75 15. stock tire was P70 15..
What that translates to i do not know...
I`m thinking of 245/55-17, with a set of TT2:s..
What do you think?
Old Aug 4, 2015 | 06:29 PM
ddawson's Avatar
ddawson
What do you think?
http://www.rimsntires.com/specspro.jsp
The 215/75-15 you have a pretty tall at 30.7". Most of us stick to the 27" size.
The 245 come in at 27.6''.
I'm on 255/45-18 at 27" It rubs a tiny bit but I need to get it aligned still.
