73 corvette
Old Aug 2, 2015 | 06:12 PM
harleyfial's Avatar
harleyfial
3rd Gear
Default 73 corvette
Need help don't know were to turn I changed the wiring harness on my 73 corvette and everything came from electric limited. The car keeps blowing the turn signal and gauge fuses. I have had the car apart three times to see if I had something pinched and I can't find anything. At one time I put the car in reverse and the fuses blow. I just check everything again and can't find anything put fuses in and everything is working only to have it happen again please help any info would be appreciated.
Old Aug 2, 2015 | 07:53 PM
jnb5101's Avatar
jnb5101
Remove the flasher can and see what happens.
Old Aug 2, 2015 | 09:14 PM
harleyfial's Avatar
harleyfial
3rd Gear
Do you think it could be the flashers there are two one on fuse box and one under passenger side.
Old Aug 3, 2015 | 09:54 AM
jnb5101's Avatar
jnb5101
The flasher on the fuse panel is the hazard flasher, the can behind the passenger dash is the turn signal unit. Try the turn signal unit first.
To 73 corvette
