rear end
Old Aug 6, 2015 | 11:47 AM
1973's Avatar
1973
Default rear end
just redid the 454 now 489 in the 73 and I am a little concerned about the rear end now as I have 575 horse and 590 torque. also would like to change out the 3.23 gear, who is the most reasonable to get parts for a new set up & make it stronger?
Old Aug 6, 2015 | 03:39 PM
lurch59's Avatar
lurch59
IMHO you'll need to upgrade to Tom's parts. You'll need to consider stronger spindles, half shafts and differential, how strong depends on if you'll ever run sticky tires at the tracks and whether you have a manual or automatic.
Old Aug 6, 2015 | 04:05 PM
pauldana's Avatar
pauldana
I'm at around 650hp and about that much tq out of my 427.... below is a bulletproof rear end,,,
https://www.corvetteforum.com/forums...-30spline.html
Old Aug 6, 2015 | 06:06 PM
1973's Avatar
1973
sorry I am not familiar with toms, can you send a link to the site? thank you
Old Aug 6, 2015 | 06:07 PM
1973's Avatar
1973
can I ask what a set up like that cost? thank you
Old Aug 6, 2015 | 06:16 PM
pauldana's Avatar
pauldana
$4,000 approximately
Old Aug 6, 2015 | 08:52 PM
trw's Avatar
trw
Tires will tell you how much you have to spend.
As said above sticky tires will hurt a lot of things.
Automatics have less shock to the driveline than a stick.
What is the intended use of the car?
If you can live with breaking the tires loose, it is easier on the rest.
Old Aug 6, 2015 | 09:13 PM
OMF's Avatar
OMF
http://www.tomsdifferentials.com/
Old Aug 7, 2015 | 11:49 AM
1973's Avatar
1973
thank you guys!!
Old Aug 7, 2015 | 10:03 PM
LS4 PILOT's Avatar
LS4 PILOT
Wow that's a one bad azz looking 454
Very tastefully built.
Old Aug 10, 2015 | 12:45 PM
1973's Avatar
1973
wow thanks!! can't take the credit though as my best bud Aaron came up with the build and also put it together for me, could not have done it without him- he is the best!!!!!!!
To rear end
