Middle Console face plate
Old Aug 3, 2015 | 01:55 PM
Factor's Avatar
Factor
Default Middle Console face plate
Hi all!,
trying to put 69 vert back together & snap pics for all...
BUT looking at shifter/face plate on console...the whole metal piece...and wondering if I can freshen this up? maybe with some low gloss black spray paint?
thoughts/ideas?
thanks,
R
Old Aug 3, 2015 | 02:18 PM
DABall's Avatar
DABall
I restored my console with a flat black rustoleum and a tiny paint brush and it came out great. I wanted to keep it as original as possible.
Old Aug 3, 2015 | 02:59 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Strip off all old paint, mask edges with tape.
lightly respray black paint, I like Rustolem Black Satin #777.
good luck.
Old Aug 3, 2015 | 03:34 PM
Factor's Avatar
Factor
THANKS!
how did you detail chrome letters for taillamps?
Old Aug 3, 2015 | 04:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Factor
...how did you detail chrome letters for taillamps?...
FWIW: I used the old, original 5-ball Krylon semi-flat black, but that was a while back. A hobby knife blade scraped across the letters and a q-tip dabbed in lacquer thinner removes the semi-flat black.
Old Aug 3, 2015 | 04:48 PM
69Vett's Avatar
69Vett
you can scrape or rub the fresh paint off easy,
I like to use a plastic razor blade for this, or an old credit card cutup as scrapers
if your careful, and not touch anything else.
and I just completed replacing the fiberoptics,
with Leds, for all the indicators. no problem seeing the leds work now !
Old Aug 3, 2015 | 08:35 PM
V4motorsports's Avatar
V4motorsports
Just did mine! Stripped all the old paint off and resprayed with Duplicolor Trim Paint.
Matches perfectly!
Hope this helps
Russ
Old Aug 3, 2015 | 08:38 PM
Mpls Funk's Avatar
Mpls Funk
These are great ideas...can anyone post pictures of how theirs came out with their method? I'm going to have to do this in the future as well!
Old Aug 3, 2015 | 09:53 PM
redrdstr72's Avatar
redrdstr72
I'd like to offer one more piece of advice regarding which paint to use on this project. I use SEM Trim Black in a spray can with excellent results. It's a little more expensive to buy but it flows like butter and matches the OE sheen perfectly. As has already been suggested, the chrome reveals can be cleaned up by scraping with a credit card edge before the paint cures (maybe 10 minutes after spraying). I have an extra console plate around somewhere. I will dig it up and post a pic soon.
Hope this helps.
Old Aug 5, 2015 | 09:33 AM
Factor's Avatar
Factor
Great info guys!!!
Not to sound stupid...what did I use to strip paint? And procedure?
Had a local guy say not to bother stripping and just coat it and use steel wool on the edges to clean, and a q tip w brake cleaner to take off on lettering...
Thanks for the help!!!
Ron
Hope this helps.
Old Aug 5, 2015 | 09:39 AM
Easy Mike's Avatar
Easy Mike
...what did I use to strip paint? And procedure?...
Any chemical paint stripper; follow the label directions. You can also soak the part in brake fluid since brake fluid will eat paint.
Some folks say oven cleaner will strip paint.
Old Aug 5, 2015 | 10:48 AM
Alan 71's Avatar
Alan 71
Hi mpls,
Here's an example of a shifter plate restored using Krylon #1613.
I use a x-acto blade to remove the paint from the surfaces that should show the chrome plating.
It takes a bit of time.
Regards,
Alan
Old Aug 5, 2015 | 10:55 PM
Factor's Avatar
Factor
Thanks!
Hi ALan! WOW! Great pic!
Thanks!
Ron
Old Aug 8, 2015 | 05:44 PM
Factor's Avatar
Factor
Ok...what about the heater/ax control face??
Can u reprint this? Anyone successful? Or easier to purchase...
Old Aug 9, 2015 | 09:45 AM
Easy Mike's Avatar
Easy Mike
...what about the heater/ax control face?...Can u reprint this?...
All the console semi-flat black can be repainted. HVAC controls are their own problem since they have a clear lens in them. Depending on condition, it could be best to completely restore the HVAC controls as a separate job.
Old Aug 9, 2015 | 10:26 AM
Alan 71's Avatar
Alan 71
Hi F,
The controller lenses are readily available for only a few dollars and are a fairly easy swap when restoring the rest of the controller.
Regards,
Alan
Old Aug 9, 2015 | 01:37 PM
augiedoggy's Avatar
augiedoggy
good luck.
this is what I did... and then I covered it with the woodgrain insert since I had the deluxe interior..
I bought new lenses and shifter slider covers on ebay from a vette store... all went pretty smooth.
Old Aug 10, 2015 | 01:02 PM
Factor's Avatar
Factor
LOL!
Thanks guys!
Ron
To Middle Console face plate
