Rear Storage Compartment Assembly
Old Aug 6, 2015 | 01:39 PM
Maymyvetteliveforevr's Avatar
Default Rear Storage Compartment Assembly
This if for the 3 compartment for a '75 coupe.
I know that the doors bolt to the hinges but how do most mount the hinge to the frame if not using the stock type rivets. I need to start assembling them today and can't get the rivets in time so what are my other options?
I though I saw a write up on the "Rear Compartment Assembly" once but can't locate it anymore.
Old Aug 6, 2015 | 02:33 PM
CAMS69's Avatar
CAMS69
Don't know for sure on your 75 but on my 69 the hinges are screwed through the tray and through the Fiberglas the through a metal backing piece under the car. Iirc
Old Aug 6, 2015 | 02:45 PM
jnb5101's Avatar
jnb5101
Short pop rivets will work.
Old Aug 6, 2015 | 03:01 PM
CAMS69's Avatar
CAMS69
I guess what im saying is you could screw them down. here is a view from below you can see the metal track close to the diff molding.
Old Aug 6, 2015 | 03:55 PM
I always thought the doors were secured to the storage compartment frame, then the whole assembly was secured to the metal bracket as shown.
I'm only at the stage of securing the doors to the frame.
jnb5101Don't pop rivets have a dome type head that will impede with the hinge?
Old Aug 6, 2015 | 04:21 PM
jnb5101's Avatar
jnb5101
The short rivets should clear the hinge if the flat side faces the door.
Old Aug 10, 2015 | 06:55 PM
Mooser's Avatar
Mooser
I missed this one. Probably already on but..
The shape of the hinges allow for some clearance where the rivet heads are. The hinges are originally riveted on and the deformed head is thicker than the domed head of a "pop" rivet.
You can use the screws that hold the frame to the car (the ones that go into the metal strip shown above) to hold the hinge in place as well. Harder to align the doors within the frame but hey it's only once.
Be aware that on some cars that metal strip was pushed away at one or both ends when they were drilling the pilot holes and may not be there to grab the outer most screw
Now's a good a time as any to correct that though...
M
Old Aug 10, 2015 | 06:59 PM
Thanks for the reply jnb5101 and Mooser, this is the point I'm at now as I'm working on 6 different areas of the car depending on when I can get the parts ready for install.
Old Aug 10, 2015 | 07:59 PM
jnb5101's Avatar
jnb5101
I found that it's easier to install (at least set in place ) the frame without the doors attached. The doors are so heavy that I was afraid that the frame was going to twist and break.
Old Aug 10, 2015 | 08:49 PM
Mooser's Avatar
Mooser
And don't forget to put in the center cardboard glovebox liner before the frame gets all bolted in....
Now's also the easiest it ever gets to put that bolt in the back of the e-brake console
M
To Rear Storage Compartment Assembly
