Ignition Miss-Possible Problem with Plug Wire
Old Aug 7, 2015 | 05:11 PM
Paul L's Avatar
Paul L
Default Ignition Miss-Possible Problem with Plug Wire
I have been chasing an ignition miss for a couple of weeks now and ran down the usual list of potential problems. Today was spark plug wires. I have an over-the-top system and this wire was resting on the A/C compressor. I anchored it there with some Goop. The innards were laid bare. Am I on to something? Just kidding. That wire has been replaced. You just never know until you go through points/condensor, dwell, timing, and so on.
*Edit* - I am putting in a new NAPA/Echlin coil tomorrow just because I want to. I have my moments.
Old Aug 7, 2015 | 07:02 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
But did that fix the miss? U can spend a lot of money when troubleshooting by replacing parts. Yes that plug wire was bad. But has the miss stopped?
Old Aug 7, 2015 | 07:13 PM
Paul L's Avatar
Paul L
I will know this weekend. Too many things happening now other than the Corvette. I'll put the new coil on tomorrow and hope for the best. New R-45T NOS plugs are coming in on Monday from Michigan. That is my last resort. Could be game over for 2015.
Old Aug 7, 2015 | 07:40 PM
LS4 PILOT's Avatar
LS4 PILOT
Don't put your toys away broke .
Bad karma
Old Aug 7, 2015 | 07:46 PM
Paul L's Avatar
Paul L
Bad karma
I won't. But I won't pay someone $130.00/hr to fix this car. That is the going rate in this city.
Old Aug 8, 2015 | 02:44 AM
TimAT's Avatar
TimAT
Plug wires are not a $130 an hour project. DIY- a six pack of your favorite beverage and a sunny afternoon. One at a time. And a coil is not going to help that plug wire unless it's a coil that has a secret life as an arc welder.
Old Aug 8, 2015 | 06:57 AM
Paul L's Avatar
Paul L
I replaced that wire. I have basement spares.
Old Aug 8, 2015 | 07:21 AM
waljr's Avatar
waljr
Don't forget to check the rotor cap
Old Aug 8, 2015 | 09:43 AM
Paul L's Avatar
Paul L
Distributor cap and rotor are new.
Old Aug 8, 2015 | 10:04 AM
vbgod1's Avatar
vbgod1
If someone could find an old working SUN Tune up Tester for sale, they could be one of the most popular posters in vette land.
"back in the day... Sonny, it took longer to hook up the machine than it did to find the bad cylinder".
Old Aug 8, 2015 | 10:44 AM
Paul L's Avatar
Paul L
This is SO true!
Old Aug 8, 2015 | 03:36 PM
TimAT's Avatar
TimAT
I have one of those old Sun Tuneup Testers. Nothing replaces a good visual inspection. Nothing. It will give you loads of information if you know what you're looking at. Without the visual inspection it's a waste of time.
Old Aug 8, 2015 | 06:16 PM
LS4 PILOT's Avatar
LS4 PILOT
All fixed now and good to go?...
Old Aug 8, 2015 | 07:15 PM
Paul L's Avatar
Paul L
Back to you tomorrow. Not good tonight. Even with the new coil. But I have been lazy. I did not pull the #2 plug where the bad wire leads to. It may be fouled. But D*** it is hard to get to with that A/C compressor in the way. So up we go with the three-ton jack and jack stands. I am getting too old for this kind of work.
Might be C5 or C6 time.
Old Aug 8, 2015 | 07:55 PM
aussiejohn's Avatar
aussiejohn
NOOOOOooooooooo!!!! Say it isn't so!!!!!!
Regards from Down Under
aussiejohn
Old Aug 8, 2015 | 08:04 PM
Paul L's Avatar
Paul L
aussiejohn
I admire your humour! In 30 years of driving these Tupperware cars I have never owned one newer than 1979. And really I would probably never go newer. I am just very frustrated at the moment. But that will pass...somehow. D*** I can't find the problem!
Old Aug 9, 2015 | 11:28 PM
cardo0's Avatar
cardo0
Your a funny man Paul. U havent seen a late model repair manual. Yea its a $300 manual that looks over a 1000pages in several volumes. Or looked at a EFI data log to tune and troubleshoot. U would miss your old carb and distributor fast. And now u have 8 coils that can fail. Nearly every ignition and fuel system part is $300. Injectors, fuel pump, Power Contol Module, mass airflow sensor. All new science and might be fun for electronics engineering student but for yourself u may need a dealership close by.
Anyways u might be surprised u have a mechanical problem. Burnt vlv, bad vlv spring, wiped cam lobe, bad timing chain or timing set, even an intake/vac leak.
Im staying tuned as this is getting interesting.
Old Aug 10, 2015 | 09:03 PM
cardo0's Avatar
cardo0
We're all sorry to here that Paul. And wish u would look for a good mechanic locally. Your participation here is always an example for the rest of us.
To Ignition Miss-Possible Problem with Plug Wire
